Question about Canon PowerShot A470 Digital Camera
E24 the screen says "E24"..the "E24" word is located down left side of the camera screen...the camera isn't working
When i turn on my camera i get a e24 on the screen
In one of my canon manuals is says about E.. (see the little dots)
Camera malfunctioned. Turn off the power and turn on again, then re-shoot or play back. If the same message recurs frequentely, the camera may be damaged. Note down the error number [xx] and take the camera to a custumer support help desk. If this message happens immeadiately after you have taken a shot, the camera may not have shot the picture. Switch to play back mode and check whether the image was actually recorded.
Sorry if I can't help you more, but Canon does not give more information.
Nov 06, 2013 | Canon Powershot A1000IS Digital Camera
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
When camera is in picture mode there is a red flashing "timer like" icon on the screen. Help!
Is the date programmed on your camera? If not follow the below steps to get rid of the annoying and unsightly icon. :)
~ Press the Scene button and select Auto mode. Then OK.
~ Now press the Menu button. You should have two menu options and they are shown on the left side of the screen. Shooting menu and Set Up should be the available tabs.
~ Navigate to the left and then down to highlight the Set Up tab (looks like a wrench) then push OK.
~ Locate the Date option and push OK and set the camera clock to the current date and time.
Hope this helps!
Aug 16, 2010 | Nikon CoolPix S2 Digital Camera
Looking for connector location e24 on sentra 2001 Thanks
If you are looking for the OBD2 connector , is located under the dash left side of steering column near the hood release handle.
Apr 03, 2009 | 2001 Nissan Sentra
Hi there, I have a Canon Powershot S3IS and just lately when you try to turn it on it comes up with a message that says E24. I have looked through the manual and cannot find anything resembling this...
You have 2 choices here, one is send the camera into Canon for exchange or replace the Camera, this would be based on cost. You can't fix it as no parts are available from the manufacturer to the public.
Apr 05, 2017 | Canon G7 G9 S3is S5is S2is
Flash not working
this could be a number of problems first soloution gently hit the side of the camera where the battery is stored
if the dosent work try to pull and twist the lense gently
has the camera started to vibrate yet? and my other soloution would be
  1. ress Menu button
  2. togle across from REC Mode to setup
  3. togle down thrice from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
  14. If it is working then don't forget to set your Clock.
Sep 08, 2008 | Cameras
E24 code
Canon is replacing camera with a
CCD senor problem.......just got a new camera
go on their website and they will tell how to get it fixed
Nov 08, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
Oct 21, 2007 | Canon PowerShot G1 Digital Camera
Can't take pictures
Defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 10, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Camera Won't Start...
I believe it may be an electrical problem. try a different mem card though
Aug 31, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot A470 Digital Camera Logo
587 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
