Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Brief picture for 30 seconds, then lamp button blinks
I just had the ballast replaced on my PT-40LC12 40 inch Panasonic. I have only used the TV for a total of 5 hours, and now the lamp button blinks with no picture after I turn it on. I get a picture for 30 seconds, then blinking lamp button. Can you help me?
  • grenlove42 Dec 30, 2007
    same thing someone help
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Posted on May 22, 2008
    President:
  • 4,402 Answers
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Tv has no picture or sound. replaced bulb no help greenlight blinks 79 times. red lights start blinking
Lamp light flashing once every 5 seconds or twice every 5? Twice every 5 seconds,....lamp failure, once every 5 seconds,...ballast or thermal fuse failure. You have a lamp, ballast or thermal fuse problem. The ballasts are a discontinued part and can only be purchased used at approx. $225.00 or rebuilt for around $175.00 less any service charges to diagnois and repair.
Jan 17, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 Lamp issue
i hope the lamp was panasonic or bought in a good place (average cost of this lamp is 250 dllrs)
if the lamp is trustfully. i would put attention in the back side when you listen the arcing that the lamp at least try flashing.
This moment of the repair where you are is critical because you arrive to conclusions according to the process you already did and suspect that what it is already done is fine (but is really true that lamp works plus is really true that the arcing is because the arcing devise arcs or is only the primary of the transformers in the ballast who holds 300 volts in the primary (really good voltage to make arcing sound too)
Now the error code is going to be 50 % good or not: i mean or gives you the error of the ballast and lamp or any voltage is missed in the power supply ( i don't have the error codes chart for you with me) because i would like to go far and the problem was in the same place where i started/
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture or sound
The bulb may need replacing. If a new bulb doesn't correct the problem, then the ballast usually needs repairing.
Apr 11, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Oct 23, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
