Question about Holmes Products HCH4953-U Ceramic Compact Heater
When temp. is set it will not come on at set temp.
    President:
  • 1,187 Answers
The temp setting is not an "exact science" and is conditional:
The unit may be too close to a wall or other obstruction, such as an enclosure. It must be able to sense the temperature in the general area. When you move it, give it a few minutes the first time. After that, it will work correctly.
Posted on Oct 05, 2009
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Jun 13, 2015 | Haier Heating & Cooling
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
What is cooling and dehumidification mode
When dehumidification operation is set by remote controller,the intake air temp.is detected and the setting temp.is automatically set according to intake air temp. expl. Intake temp.78.8 set point will be 77. When intake air temp.is 2deg.below the setting temp.the indoor fan operates at iow speed or stops.It is just a way to controlle humitity rater than just temp.Some systems reach setpoint before enough humitity is removed,making house feel stuffy,or damp.
Mar 07, 2010 | LG LSC183VMA Split System Air Conditioner
Temp setting worn off and difficult to set temp
call region repair center to get & order new temp control dial.
Nov 17, 2009 | Kitchen Ranges
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Delonghi cf210 when setting temp it dosnt give any heay
just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Jul 27, 2008 | DeLonghi CF210 Portable Air Conditioner
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Holmes Products HCH4953-U Ceramic Compact Heater Logo
93 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
