Question about Kohler K-3464-0 White Serif Serif Two Piece Elongated Toilet with 12" Rough
How to increase fill rate - Kohler K-3464-0 White Serif Serif Two Piece Elongated Toilet with 12" Rough
  • 302 Answers
There should be a small water valve on the back side of the toilet along the wall.
Turn this valve to increase the fill rate.
Posted on Oct 06, 2009
Will A Request For Line Of Credit Increase Affect My Credit Rating?
Whenever you request a line of credit increase online, the lender will review to find out your qualifications won't impact your credit rating. To check on your qualifications to have an increase, the lender make use of the information that people normally receive in the credit agencies every month. This doesn't generate yet another inquiry.
Sep 18, 2015 | Computers & Internet
When putting gas in my 2004 Kia amanit the fuel nozzle kicks off. How do I locate and fix the problem
HI Bridgette,
Due to the different shapes of fuel tank filler necks in cars & trucks, it may be necessary to vary one or more things to allow fuel to flow uninterrupted until the tank is really full.
The main problem can come from the new "vapor recovery" gasoline pumps. These pumps and hoses actually recover gasoline fumes from your tank as the liquid gasoline displaces the air / fumes in the tank is it is being filled. If gasoline flow is started at full blast, it can splash back slightly, causing liquid to be pulled back by the pump - so it shuts off. So, start with a slow rate of filling and gradually increase flow rate to maximum over 5 to 10 seconds. If it still shuts off, try some of the suggestions below.
First, don't fill at maximum flow rate from the pump - that is, don't set the nozzle for wide open. Select one of the other "latches" on the handle instead of the fastest flow and let the tank fill entirely at this rate.
Second, you should experiment a bit with the length of nozzle that you push into the tank's filler neck. If you push it in too far or too little, the pump nozzle can do what you're describing.
Third, try twisting the nozzle slightly so that it doesn't hang straight downward - a little to the left or right may provide a solution.
Lastly, try a different gas station. Their pumps may not be so picky with your tank's filler neck.
Jun 14, 2012 | 2004 Kia Amanti
How do you release an air lock in the coolant system of a 05 chevy equinox?
2 ways you can by a special tool that release airlock that will vacuum the system of any air or you can do the effective way both will work. Do it this way if you want to get the air out youll need another person in the car to step on the acclerating pedal (no more cable) . 1. block the drive wheel set the e brake on. 2. fill the radiator up as much as it will get. 3. fill the resovoir (its okay to over fill this bottle itll just overflow out) 4. have your helper get in the vehicle and acclerate to 1500 RPM. with the radiator cap open and as you accelerate the coolant will move around youll need to have the cap in the ready position as it will want to come out the radiator. during that time youll cap it. and maintain 1500 RPM. once the car reaches thermostat opening the fuid will sink. at this time feel the radiator hose and command higher RPM and when the radiator hose collapse your safe to open the cap and fill. fill it up. put the cap on ,have the RPM drop to idle feel the radiator hose is it hard. Now because its hard it increased in pressure,because of this pressure you cannot open the radiator unless you want to get wet. Have your helper increase RPM go to 1500 RPM test radiator hose, the moment it collapse is the moment you can add coolant or water add and seal radiator. Let idle due this procedure untill you are sure all air is out,eventually the cooling system will get to the point where you cant do it any more. Here is how the theory work when coolant is under pressure it boils at 110 F if you pressure it 1LBS it increase in temperature radiator cap rated increase the boiling point to 210 F this is the optimum where all sensor go into fuel control. When you do this high RPM method you chase out the air air wants to float out and a the same time water wants to boil so you are chasing and controling two different . arenas. The high RPM propell the fluid to sink and air to rise the putting in idle stabalizes the fluid and air and allows it to seek a natural enviroment. you have 3 tools in your hand the radiator cap, the RPM control,adding of fluid. This works for me I just dont want to buy tool.
Apr 24, 2011 | 2005 Chevrolet Equinox
Rinse cycle water is very slow to fill, it just trickles into the tub.How can I increase the flow rate; all other cycles fill at a "nornal" rate.
most likely you have sediment in the water valve,you can check by shuting off the house water shut off to the washer,mark the hoses so you'll know where they go when you reconnect them,remove the hoses,stick them in the washer or in a bucket,turn the water back on,if the pressure is good then you know the problem is in the water valve on the washer,call your parts store,give them the model number off of the washer and they will sell you the correct water valve and you'll be all set.
Mar 30, 2011 | Washing Machines
How do I adjust image so it fills the screen, side to side and to bottom?
Using the buttons on the screen, bring up the menu.
Then using up/down or left/right buttons navigate to a picture that show a squre that has arrows showing to increase screen size in the approite direction. Select this picture and use the arrows to either increase or decrease size.
Your timeous rating of this solution is much appriciated.
Thanks
Nov 01, 2010 | LG W2243T-PF Monitor
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
2009 Saturn Vue Hybrid 1400 getting 18 mpg instead of avg of 28
Do you normally accelerate quickly from stopped? You can increase your cars mileage by cutting down on rapid starts and stops. A comparable Honda Accord Hybrid rated at a higher 25city 37 hwy MPG rating achieves less than 22mpg when driven HARD
Jul 11, 2009 | 2009 Saturn VUE Hybrid
Water does not cut off after filling.Model 110-82870100
Water fill switches usually have an air tube that as the water level comes up the air pressure increases and causes the switch to go from fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some times the switches also get out of calibration and need readjusting (especially if you have moved in altitude like up a mountain or into a valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Kenmore Washing Machines
Keeps filling up with water will not wash
Mar 13, 2009 | GE Profile WPRE6100G Top Load Washer
Kohler K-3464-0 White Serif Serif Two Piece Elongated Toilet with 12" Rough Logo
208 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
