I have a Canon EOS 40D When I switch it on all appears fine. When I take a photo the shutter remains open & all power is lost. I then need to remove & re-install the battery to recover power.
I can view existing photos on the memory card but as soon as I switch to take a photo & click the shutter, the above happens again.
Before I decide next steps I was hoping someone out there could help.
See if the problem is related to the memory card. Start by ejecting the memory card and after saving to disk via card reader, format the card. If there is a problem writing to the card, it will probably show up during the format process. Or, insert a *different* card into the camera and take a shot. The likelihood of two cards being faulty is slim, so if the problem is related to the camera (same problem with both cards) you'll find out by doing the above steps.
If both cards are causing the same results, double check the camera settings - set to full Auto mode and take a shot of a brightly lit scene (or set to manual mode set the lens to wide open (lowest f number f2 to f5 or so) and exposure time to 1/250 - 1/500 and shoot a brightly lit scene. If the shutter opens & closes as expected, double check the settings - as the camera is probably OK, but just set wrong. if still having problems, it might need a vistit to the repair shop. Good luck!
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 40D Digital Camera
when I press the shutter button I can hear the mirror flip up and then camera goes dead. I will have...
(More)
when I press the shutter button I can hear the mirror flip up and then camera goes dead. I will have to remove the battery and I can hear the mirror flip down (canon 40d)
usb device not recognised canon 400d been using usb port every day for almost a year today says does...
(More)
usb device not recognised canon 400d been using usb port every day for almost a year today says does not recognise my device.
My Canon 40D turns off when I press the shutter. The focus points highlight, camera focuses and sets...
(More)
My Canon 40D turns off when I press the shutter. The focus points highlight, camera focuses and sets exposure (flash even will strobe), but then the camera "freezes" and turns off. I've tried inserting several different Canon batteries (fully charged) with no luck. Any thoughts?
My Camera is Canon 40D with EFS 17-85mm lense. I am having 2 problems,1.when I zoom the lense at 85...
(More)
My Camera is Canon 40D with EFS 17-85mm lense. I am having 2 problems,1.when I zoom the lense at 85 at 'AF' it doesn't get the focus, some times it get focus but picture got blurred.2 after capturing some pictures an error appears 'err 01'the contact between the lense and the camera is faulty. i need some immediate solution
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
