Question about Konica Minolta magicolor 2400 Laser Printer
Printer will not feed paper
My Konica 2400W Printer will not feed paper
  • 214 Answers
SOURCE: 2400w Konica Minolta Magiccolor
dont understand your problem quite well, but, for a connection problem, update driver, change usb cable and last if nothing helps, update firmware.
for a paper take up problem,:
turn off printer,
remove cover,
remove drum cartridge,
under that there is take up roller, pull the knob and move the roller to right, then you can pull the take up roller out.
first try to clean it and also clean plate under the take up roller. if thats not helping, then you have to cut the biger (larger) plastic sides of the take up roller a little smaller..
should help.
good luck
Posted on Feb 11, 2008
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
  • 3 Answers
SOURCE: Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Posted on Aug 11, 2008
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
  • 118 Answers
SOURCE: Paper Feed errors on 2400W
Over time time the feed rollers get covered in paper dust and toner and such. They then will slip while pushing the paper, and it does not get all the way to the sensor to say the paper is ready. Just carefully clean them with a little Fantastic or similar cleaner.
I just install a konica minolta magicolor 2400w printer on a computer thats running vista. Everything seems to be installed correctly but when I go to print something, it would not print, the ready light...
I have a Konica user guide for your printer here:
2400w User guide PDF
Have a look at the introduction and troubleshoot sections for the light blink codes, these give you an idea if it could be an error.
May 14, 2010 | Konica Minolta magicolor 2400 Laser...
How to specify the appropriate media type in the printer driver with the Konica Minolta 2400W
Go to printer properties -> Printing Preference -> Paper -> Media Type
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 13, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Paper feed issue
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Jun 04, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400w will not print
will print??? or the paper not coming out of the draw does it work using the bypass tray???
Jun 03, 2017 | Konica Minolta magicolor 2400 Laser...
BADLY IN NEED OF PURCHASING A GENUINE FUSER FOR MYMINOLTA 2400W AS THE LASER PRINT INK WONT FUSE TO THE PAPER. CAN YOU HELP
A search on Google for "konica 2400w fuser" turned up a few sources. Here is one I picked as an example. You can try searching based on the manufacturer's part number as well, as that may come up with additional sources and prices. Good luck with your search!
May 01, 2009 | Konica Minolta magicolor 2400 Laser...
Paper got stuck in Konica Milolta magicolor 2400w
I had the same problem and this worked, although it is not the answer to your question:
Take a standard manila file folder and cut it to the basic shape of a standard piece of paper. When you lift the top cover on the under side you will see a diagram on how to pull the paper out in the case of a paper jam. Feed you file folder up from the bottom and you will ~ with a little work, more than likely be able to clear the jam.
Feb 20, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
It is a timing issue, mine does the same thing. Here is fix. Open top door, remove drum cartridge, look inside for pickup roller ( the one that is shaped like a half-moon) reach down there and rotate it towards the front of the printer and downward so the curve ends up being pointed down to the bottom of the printer. You should here a loud click, that is the cam being reset. The cam is to the left behind the 2 gears. remove any paper feed jam, reinstall drum and close the top lid. This should reset it back correctly. Do the above steps with paper in tray and the power left on. Do not reset the printer after resetting cam position. Also it might take a few attempts to get the timing reset right, so dont give up after 1 failed attempt. I have had to do it 10 times before to get the timing right. Just make sure the curved area points downward.
Sep 27, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
