Question about Karcher K2.26 Electric Power Washer
Motor runs fine but pressure output has dropped by 50% Karcher K3.97 about 3 years old
4 Suggested Answers
jmgldsmth
  • 1889 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
wiringlunati
  • 576 Answers
SOURCE: karcher k3.86 motor runs but has no pressure when
Could be a pump, but most likely the unloader valve is stuck open. After replacing/repairing the valve, do the following to prevent it in the future: after finishing using it, unhook both hoses and pull the start cord on the engine several times to empty the water from the pump and valves. This is especially necessary when using hard water.
Posted on Nov 20, 2009
  • 299 Answers
SOURCE: Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Posted on Apr 16, 2010
Testimonial: "Thanks brobin, your advice was spot on and it is now working again, much appreciated"
Karcher K2.54M loss of all pressure
I have seen it before where the little plastic pistons overheat and melt. The unit still runs but with no pressure. I would pull the pump apart and check the pistons.
Sep 03, 2012 | Dishwashers
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
Apr 16, 2010 | Karcher Garden
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher K2.26 Electric Power Washer Logo
673 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
