Question about HP Officejet 5610 All-In-One InkJet Printer
Cartridge error message
We have tried to fix this, ready to throw out whole thing.
Anyone fix this problem? I have the user guide but there's nothing in there which is helpful.
Thanks.
obzzen
  • 5 Answers
SOURCE: Printer error messages
* use the replace cartridge maintenance of your printer. try to remove again and re-insert the cartridge, make sure you properly follow the procedures and the cartridge is place on right. * look for jam paper also inside the printer. push the feed button. * if your using Windows XP, go to your Control Panel, then Printer and Faxes, and look for your printer device name. right-click on it and check Set as Default Printer if is not. and right-lick again look and click for Use Printer Online if you see one. uncheck also if you see Paused Printing checked. You can also tweak the Printing Preferences... menu. I'll gladly help in any way I can
Posted on Apr 05, 2007
bapplay
  • 40 Answers
SOURCE: HP PSC 750
Have you tried running the software that came with the printer and have that do alignment and reconfiguration for you...that should work
Posted on Apr 30, 2007
SOURCE: Printer Fixing Error- Replace Fixing Unit
You need to replace the fixing unit. It costs $120 and replacing it is not a trivial job. You may be better off buying a new all-in-one (not necessarily an HP). I've had good luck (so far) with Brother.
Posted on May 05, 2007
SOURCE: Cartridge error
I have a hp officejet all-in-one 6213 series printer . It was bought in South Africa about 2 yrs ago , now I am living in London ,England I have moved regions and the cartridges which were used in SA were hp 131 and hp 135 . I have found compatible hp 344 & 338 cartridges here in the uk ; but when I inserted them into my all- in- one system TH READING FROM THE SYSTEM STATES THAT there is a CARTRIDGE ERROR FOR USE IN THAT PRINTER. My question is how do I make my system accept these cartridges ? Lenna15
Posted on Jan 17, 2008
SOURCE: print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Posted on Jul 08, 2009
My black cartridge was running low but was still printing. Then I got the Cartridge error message and to consult my user guide. I have misplaced the booklet. I replaced the black ink cartridge and...
Welcome to Fixya. If you lost the user guide on how to fix the error perhaps the link below will help you out your problem. It contains solution on how to fix cartridge error and the proper way to replace cartridge.
Dell AIO 948 Troubleshooting
Thanks
Jun 17, 2011 | Dell 948 All-In-One InkJet Printer
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Brother mfc-210c, error message "Unable
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 15, 2010 | Brother Office Equipment & Supplies
Printer Cartridge Error Message
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 03, 2010 | Lexmark X7170 All-In-One InkJet Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Flashing alarm and 'put in cartridge' Canon woe's
Hi, I tried hitting the stop button (well I pressed it, even though I felt like hitting it)
Nothing happened.
Using genuine cartridges, haven't tried a re-fill, tape is removed
Canon say the cartridge holder may be at fault but printer has barely had any use (do they die of old age?)
It just keeps flashing at me and message is 'put in cartridge'
Jul 13, 2008 | Office Equipment & Supplies
Cartridge slamming
I have a Dell 924 and the SAME thing is happening to me! it is probably because something called the cartridge band has disconnected. it is actually a thin small clear band that connects to either side of the inside of the printer to guide the cartridge. Unfortunatly, if you don't still have a warrenty with Dell to get it fixed or replaced, you might have to buy a new one or fix it yourself. :(
Feb 01, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge error error 50C consult user guide
Hello, error 50c is a cartridge issue. Try taking out, cleaning heads, returning and reprint. Cheers lilacgerry xxx
Dec 02, 2007 | Lexmark X6170 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
