Question about Sharp XR-1S Multimedia Projector
SHARP XR-1S won't turn on
There seems to be a problem with my Sharp XR-1S projector. when i plug it in and turn it on the standby/on button goes from red to green and there's a brief beep from the machine. then the lamp and fan turns on while the projector looks for an input source and after about 5 seconds the lamp and fan turn off. the standby button turns red and the machine won't turn on again unless i unplug it and start over. this happens whether there's a source plugged in or not.
  • 1 more comment
  • jbickett Sep 08, 2008
    I am experiencing the same problem. Has anyone found a solution?
  • grahamkida Oct 04, 2008
    Same problem - after removing dust from air intakes - PLEASE HELP
  • jwm8 Dec 14, 2008
    Brand new unit. On start up, fan motor and lamp turn on and leds on top
    go through initialization routine. Notevision spash screen displays and
    gives message "warming up". After a few seconds just after the lamp
    gets brighter, system displays message "shutting down" and does without
    giving startup/setup screens. Same behavior on several laptops (Win and
    Linux Ubuntu) with either usb or monitor cable. This is a brand new
    unit, never used, so no bulb life consumed. Removed and reseated bulb
    with no change. No visible "reset" button inside unit where lamp seats.
    Can't find any similar problem on internet forums other than dust on
    ventilation louvers causing lamp to overheat and shut down. This does
    not apply to this unit as it is clean, brand new.
OK - I've fixed mine (so it looks) - loads of dust inside unit seemed to caused the problem - vacuuming vents (as the manual prescribes) just shifts all the dust inside around and obviously causes some disruption.. solution - remove 4 screws underneath and lift off top (carefully) remove side panel screws (where Av inputs are) again carefully. Now go around each vent at the front, side and underneath and give areal good blow in each a few times. Plumes of dust and rubbish fly out - keep going until it's all clear. Reassemble and fingers crossed. Mine then started up and didn't turn off - there's a horrible burning smell (dust settling near lamp I presume) which is now fading. Been working 30 mins now with no trouble!
Hope it works for you - will post another update if I have any further problems - no news is good news!
Posted on Oct 04, 2008
Sharp Conference Series xg=ph50x Wont turn on..The red light comes on but it wont do anything may be locked.?? Any ideas??
Posted on Jun 27, 2012
I also face same problem here....
Posted on Apr 25, 2008
Will not get power
the power supply is bad and need to be replaced. you can get the part and do it yourself, or send it to a sharp service center. either way, try av solutions in ny. they're really good.
Jan 27, 2010 | Sharp XR-1S Multimedia Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
make sure the resolutions match. change it on the projector.
Mar 30, 2009 | Sharp Notevision XR-1S Slide Projector
Connecting the Sharp XR-1S to the macbook pro
Hi contact me if the issue persist and post me a message here
Jul 26, 2008 | Sharp XR-1S Multimedia Projector
you'd be better off hooking the dvd up to an amp and run speakers off of that.
Jul 17, 2008 | Sharp XR-1S Multimedia Projector
Sharp XR-1S White vertical stripe
HI there
This could be a costly exercice as this is a common Projector Mainboard failure.
You can either replace the board or have it repaired.
Apr 10, 2008 | Sharp XR-1S Multimedia Projector
I have a Notevision Sharp xr-1s projector and it wont work with my windows vista laptop. I tried it on my vista pc and xp laptop and it works fine.
Jun 20, 2007 | Sharp XR-1S Multimedia Projector
Sharp XR-1S Multimedia Projector Logo
522 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
