Question about Kirby G4 Bagged Upright Vacuum
My kirby g4 will not turn on. I have checked the fuse and flex, the switch sounds good. pleas advice
    Scholar:
  • 116 Answers
Ensure the front housing is properly fitted and the bottom of the bag housing that attaches to the machine, if these are not located correctly the safety switches will not allow the vacuum to start.
Could also be the mains cable, any damage may not be visible on the outside.
Or the motor brushes may be worn out, you will need a professional repairer for this.
Posted on Jan 02, 2010
G4 kirby do the rear wheel actually turn by themselves with power assist
Thanks
Posted on Aug 05, 2011
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
When motor is switched on, power supply tripped and fuse burned.
sounds like field has grounded, you will need to get a Kirby engineer
Nov 29, 2012 | Kirby G4 Bagged Upright Vacuum
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
My Kirby G4 will not turn on, how do I tell what is wrong??
remove the switch that turns it on and test the continuity with an ohm meter.Also check the cord as well for that may be at fault
Jun 27, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby g4 tech drive, when plugged won't come on ,is it the motor or something else ?
Does anyone know if there is a reset button on the Kirby G4? And if there is where it is?
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 stopped working
maybe the impeller broke, that is the most common reason for '' loud noise''....then you must remember that the kiby will not switch on [ all G models ] if the bag and the front nozzle is not properly attached.....
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
299 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
