Question about Samsung WF337AA Front Load Washer
Mouldy clothes!!!!!!!!!!! Hi there we have a samsung front loader just over a year old and it goes through its cycles but doesnt seem to be washing the clothes they come out smelling mouldy, we were advised to run a cycle with eukaliptus oil through it but it hasnt worked, any ideas? thanks and a merry christmas
  • Anonymous Mar 27, 2014
    Clothes have tiny black grease dots after washing
I had this same problem along with the washer wasn't spinning all the water out and was very noisey! the repair man that samsung sent out said there are alot of these washers with the same problem, he thinks it's a defect in the machie design. i'm awaiting the 4th repair on mine in 2 months and samsung won't replace!
Posted on Apr 22, 2008
  • 1,294 Answers
Same to you
Posted on Dec 23, 2007
  • prem mathew Dec 23, 2007
    Double check in and around the door boot. A lot of times small articles of clothing, lint and other forms of debris get caught behind the rubber and begin to stink. Continue with the clorox and hot water washes as a preventive measure. Depending on frequency of use, you may want to run the washer on its HOTTEST cycle with only bleach more OFTEN. Now...if don't find anything behind the rubber door boot,and the smell persists, you may want to check your drain pump as well. Make sure you drain all the water from washer by using a shop vac to pull a vacuum on the drain hose in the back of the washer. This will pull all the remaining water from the tub, through the drain lines and through the pump. Sometimes this will also pull any debris from the lines. Remove the lower kick panel under the door and check the drain pump for obstructions. The pump on this model have a screw off cap that you can check. As a last resort, if everything else checks out, is to replace the door boot. The rubber will sometimes become so mildewed that it will not go away and the smell will linger. I hope you find this information helpful. Let me know if you have any further questions. <>
    PS Do not use a wire brush on the rubber door boot. Use a green scrub pad or nylon bristled brush instead. You may case damage to the rubber.
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
Hi washing not coming out clean i have sat and watched washer and it goes left about 6 turns and then right 6 times during washing door temp is very hot on 90 deg setting it goes through its cycle and...
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Zanussi ZWF1430W Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Rim around machine is mouldy. How do I clean or replace it?
run your washer thru a wash cycle with a cup of vinegar instead of soap. Do not put clothes in with it.
May 20, 2009 | LG WM2688H Front Load Washer
Zanuassi jet system frony loader has a bad smell
hi this is joyce
They sell a product called affresh it cost about $10.00 you put in the machine and run a cycle and this should take care of the smell. if this does not do it then run pure bleach in despenser and run cycle no clothes in washer. this will kill the mold. also never close the door completly on the machine because this holds moisture inside the machine, so leave a crack in door so the machine will dry out some. this should take care of the problem.
Feb 05, 2009 | Zanussi ZWF1430W Front Load Washer
Stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Mar 11, 2008 | Samsung WF337AA Front Load Washer
Smelly clothes
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at
Note: Also go to -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
And dont forget to rate me pl. Merry Xmas to you too.
Dec 22, 2007 | Washing Machines
Samsung WF337AA Front Load Washer Logo
675 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
