Question about Microsoft Video Game Consoles & Games
How do i turn off familysettings if is not valid
  • 25 Answers
Press the xbox button in the middle of the controler. got to perferences. and the should be a parental settings option thee.....adjust to what you like
Posted on Oct 07, 2009
Program the keyless entry
i guess you meant HOW CAN I program? (key word "I")
is car USA car?????? (our rules are UNIQUE)
the operators guide on all jeeps cover this.
posted this 100s of times here.
there are lots of rules related to this.
first off most newer cars, you need 2 keys to make a 3rd.
and has a 8 key limit,
and new key must be new, as used ones will not program.
tricky huh? and gets worse in time, the 2010 you cant do at all.
my 08 can do. and did.
see?
the car came with 2 keys, lost one?
that be first first.
lost operators guide, even look yet?
WJ jeep year 2000
ill read the book for you.
veh. theft security chapter.
chapter 8q in the FSM.
page 7 , "customer method"
ill see if i can paste it here, (found it in 10 seconds)
quote, real FSM
CUSTOMER LEARN METHOD
The Customer Learn feature is only available on
domestic vehicles, or those vehicles which have a
U.S. country code designator. This programming
method also requires access to at least two valid Sentry
Keys.
If two valid Sentry Keys are not available,
or if the vehicle does not have a U.S. country code
designator, the Secured Access Method must be used
to program new or additional valid keys to the SKIM.
The Customer Learn programming method procedures
are as follows:
(1) Obtain the blank Sentry Key(s) that are to be
programmed as valid keys for the vehicle. Cut the
blank key(s) to match the ignition switch lock cylinder
mechanical key codes.
(2) Insert one of the two valid Sentry Keys into the
ignition switch and turn the ignition switch to the
On position.
(3) After the ignition switch has been in the On
position for longer than three seconds, but no more
than fifteen seconds, cycle the ignition switch back to
the Off position. Replace the first valid Sentry Key in
the ignition switch lock cylinder with the second
valid Sentry Key and turn the ignition switch back to
the On position. The second valid Sentry Key must
be inserted in the lock cylinder within fifteen seconds
of removing the first valid key.
(4) About ten seconds after the completion of Step
3, the SKIS indicator in the instrument cluster will
start to flash and a single audible chime tone will
sound to indicate that the system has entered the
Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer
Learn programming mode, turn the ignition switch to
the Off position, replace the valid Sentry Key with a
blank Sentry Key transponder, and turn the ignition
switch back to the On position.
(6) About ten seconds after the completion of Step
5, a single audible chime tone will sound and the
SKIS indicator will stop flashing, stay on solid for
three seconds, then turn off to indicate that the
blank Sentry Key has been successfully programmed.
The SKIS will immediately exit the Customer Learn
programming mode and the vehicle may now be
started using the newly programmed valid Sentry
Key.
Each of these steps must be repeated and completed
in their entirety for each additional Sentry
Key that is to be programmed. If the above steps are
not completed in the given sequence, or within the
allotted time, the SKIS will exit the Customer Learn
programming mode and the programming will be
unsuccessful. The SKIS will also automatically exit
the Customer Learn programming mode if it sees a
non-blank Sentry Key transponder when it should
see a blank, if it has already programmed eight (8)
valid Sentry Keys, or if the ignition switch is turned
to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle
while in the Customer Learn mode (SKIS indicator
flashing), the SKIS will respond as though the vehicle
were being started with an invalid key. In other
words, the engine will stall after about two seconds
of operation. No faults will be set.
NOTE: Once a Sentry Key has been programmed as
a valid key to a vehicle, it cannot be programmed
as a valid key for use on any other vehicle.
end quote.
got all that?
if confused, ask any ASE shop in USA for help
they CAN DO !
Dec 13, 2015 | 2000 Jeep Grand Cherokee
I un connected the battery to my dodge charger 06 and then reconnected it now it will not start what could be wrong with it
The Customer Learn feature is only available on domestic vehicles, or those vehicles which have a U.S. country code designator. This programming method also requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, or if the vehicle does not have a U.S. country code designator, the Secured Access Method MUST be used to program new or additional valid keys to the SKREEM/WCM. The Customer Learn programming method procedures are as follows:
  1. Obtain the blank Sentry Key(s) that are to be programmed as valid keys for the vehicle. Cut the blank key(s) to match the ignition switch lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
  3. After the ignition switch has been in the On position for longer than three seconds , but no more than fifteen seconds , cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
  4. About ten seconds after the completion of Step 3, the security indicator in the instrument cluster will start to flash to indicate that the system has entered the Customer Learn programming mode.
  5. Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
  6. About ten seconds after the completion of Step 5, the security indicator will stop flashing, stay on solid for three seconds , then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKREES/ SKIS will immediately exit the Customer Learn programming mode. After the ignition is cycled the vehicle may be started using the newly programmed valid Sentry Key.
NOTE: The Remote Keyless Entry (RKE) Transmitter will also be programmed during this procedure.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKREEM/ WCM will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKREEM/ WCM will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds .
NOTE:
  • If an attempt is made to start the vehicle while in the Customer Learn mode (security indicator flashing), the SKREES/SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation. No faults will be set.
  • Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
Jun 09, 2011 | 2006 Dodge Charger
How to reset my 360 familysettings
Call microsoft tech support; they will give you a temporary code to override any passwords on the console. 1-800-4MY-XBOX.
Mar 15, 2011 | Microsoft Xbox 360 Console
Can i program a time schedule for x box to be accessed through th
Sounds like you are looking for the "Family Timer" feature of the Xbox 360.
go to My Xbox, open System Settings, and selectFamily Settings, Console Controls.
As shown here: http://www.xbox.com/en-US/support/familysettings/console/xbox360/consolefamilysettings.htm
May 14, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
We have forget our familysetting passcode give us a code immerdiatly
Here is what you can do
To reset your pass code after you've forgotten it:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Apr 10, 2010 | Microsoft Xbox 360 Console
How do i setup my router to shut down the udp port at a certain time....xbox live is what i'm trying to control
Your router does not have the advanced features that would be needed to do this. However, this can be controlled using parental controls on xbox live. Here is a link: http://www.xbox.com/en-US/support/familysettings/xbox360/familysettings-intro.htm
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Family settings
hahahahahahahahahahahahahahahahahahahahahahaha sorry but hahahahahahaha
u need 2 be dumb
Jan 04, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
