Question about Epson Stylus Pro 9600 InkJet Printer
Maintanance required # 0400
Error # 0400
  • 95 Answers
Can you specify the error again like
what happened before you got the error message?
Posted on Oct 05, 2009
Tip
Sign of Virus Infection
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
You can easily identify when yourcomputer system gets infected from viruses. Some of the signs of virusinfections are enlisted herewith: Computerbecomes very slow in performance.
Suddensystem crashes and computer reboots repeatedly.
Applicationsoftware crashes and random messages are displayed on the monitor.
If you find any of the above mentionedsign on your computer system, then there arises the probability of yourcomputer being infected with viruses. The next step after detecting thepresence of virus on your PC is to remove them from your system in order tosave your important data. If your computer is not infected with any type ofmalicious software then it is strongly recommended to install any bestantivirus software to keep it safe against the attacks.
on Jan 28, 2010 | Computers & Internet
Tip
Secret Codes For SGH-600/SGH-2100
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the secret Codes for SGH-600 / SGH 2100
  • *#06# -> Show IMEI
  • *#9999# -> Show Software Version
  • *#0837# -> Show Software Version (instructions)
  • *#0001# -> Show Serial Parameters
  • *#9125# -> Activates the smiley when charging.
  • *#9998*228# -> Battery status (capacity, voltage, temperature)
  • *#9998*246# -> Program status
  • *#9998*289# -> Change Alarm Buzzer Frequency
  • *#9998*324# -> Debug screens
  • *#9998*364# -> Watchdog
  • *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
  • *#9998*427# -> Trace Watchdog
  • *#9998*523# -> Change LCD contrast - Only with version G60RL01W
  • *#9998*544# -> Jig detect
  • *#9998*636# -> Memory status
  • *#9998*746# -> SIM File Size
  • *#9998*778# -> SIM Service Table
  • *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
  • *#9998*837# -> Software Version
  • *#9998*842# -> Test ******** - Flash the screenligth during 10 seconds and vibration activated.
  • *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
  • *#9998*872# -> Diag
  • *#9998*947# -> Reset On Fatal Error
  • *#9998*999# -> Last/Chk
  • *#9998*9266# -> Yann debug screen (=Debug Screens?)
  • *#9998*9999# -> Software version
Enjoy. :)
on Dec 14, 2009 | Cell Phones
Maintanence required is blinking when starts
Sounds like your car needs a tune up. At a certain mileage the car probably needs an oil change and other maitanence. Go on YouTube and watch a video to reset the button. Good luck.
May 31, 2014 | 2005 Honda Accord
Maintanence required light
A maintenance required light means some type of maintenance is required on your car. It wont clear until the maintenance is done. Unfortunately you will probably have take it to a dealer for repair and clearing the code.
Aug 23, 2012 | 2005 Lexus Ls 430
Hello, I have a 2002 honda civic ex. When I turn the key on I get the maintanence required light. after the engine starts the light blinks 10 times and then goes out. I couldn't find any guidance in the...
First, make sure you are talking about your mainanence required light, and not your check engine light.
Your maintanence required light is telling you that some normal maintanence is required since you have traveled some pre-determined number of miles (pre-determined by Honda). For example, it could mean an oil change should take place, etc. If you keep track of those things on your own, then you need only reset the light, as follows:
Turn off the engine.
Press and hold the Select/Reset knob (odometer) in the instrument panel, then turn the ignition switch just to ON (II). Do not start the car.
Hold the knob for approximately ten seconds until the indicator resets.
Hope this helps you.
Oct 29, 2009 | 2002 Honda Civic
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Jun 20, 2009 | Canon CLC 1150 Color Copier
I have a Fridgidaire stove FE369COSE. Ran self cleaning cycle but now oven door won't unlock. Oven is cool but an error code of f9 is flashing. Does anyone have a solution? jadimin
I've had this happen with my Frigidaire stove too. The "locked" light is on.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Open the oven door and locate the light switch. Hold it in - sometimes it makes a noise and resets it.
If that doesn't work, push the Clean button and the Cancel button simultaneously and hold for about 30 seconds. The “locked” light should disappear. If it is working, you’ll hear a mechanical hum as it resets.
Apr 14, 2009 | Frigidaire PLEF398AC Electric Kitchen...
New Epson RX595 won't print
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
May 18, 2008 | Epson RX595 Photo All-In-One Printer
Konica Minolta Di 520
Try resetting the copier first, power on - open the front door remove small cover on the right hand side press reset button - close door. The machine should now boot, but if the fault is still present a service call will be required.
May 09, 2008 | Minolta DiALTA Di520 Laser Printer
Epson Stylus Pro 9600 InkJet Printer Logo
328 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
