Question about E-Machines T6528 PC Desktop
Computers has power but will not turn on monitor,fans on blue light on, yellow light constant. cd slide opens and closes normal.
    Problem Solver:
  • 7 Answers
Do you have a secondary video output source on the back of your PC, if so, it is posible that the source may have switched.
You can also check to make sure that your monitor is working by selecting the menu button on the monitor. If it comes up then your monitor is on. Check all of your video cables to make sure they are connected.
Some monitors have different input sources check to make sure your not on the wrong input source. This should be found in the menu section as well.
Posted on Oct 05, 2009
    Sergeant:
    Novelist:
  • 191 Answers
First the obvious, monitor is on? Cables are connected securely to back of monitor and PC? Power cable/power adapter are all connected and plugged in? If a power adapter is used, it will feel warm.
I am assuming it was working on some point and then stopped.
If you are getting power to monitor and it's power light is on, then I'd suggest a problem with the video output on PC
If you are not getting power to monitor or it's light is not on, the problem is with the monitor.It may have gone out on you. Try attaching to another computer.
546 will turn on normally(light is blue) but won't display my monitor and usb ports power some items and not others.
You probably dislodged some components in your computer after it fell. Suggest that you open the computer and re-insert the memory modules and other cards inserted in the motherboard. Unplug it first and on a non static surface like a kitchen table.
Mar 22, 2014 | Dell Inspiron 546 MT Desktop Computer
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
My monitor is not connected to the computer but everytime i turn it on the whole screen turns blue, then yellow then white etc.. how do i fix it
That could be normal operation if it is not connected. Does it do the same when connected? If so, try another monitor. Does the computer power on normally otherwise?
Dec 13, 2008 | Computers & Internet
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Intermittently the power button constant orange fan full speed
Try removing the battery from the motherboard if its not soldered and leave it for an hour then out it back in, that might reset you bios and fix your problem.
Nov 25, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
E-Machines T6528 PC Desktop Logo
225 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
