Question about Kenmore Dehumidifiers
Kenmore dehumidifier M/N 580.53650200 only runs for about 2 minutes, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the compressor runs, and doesn't get hot, and there are no bad noises coming from the unit. Any ideas?
2 Suggested Answers
SOURCE: Kenmore dehumidifier M/N 580.53650200 only runs for about 1 min
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Posted on May 02, 2010
Why isn't it dehumidifying?
The compressor may not be running. You could be hearing just the fan.
You may not have humidity level selected
You may not have cycle time selected
The condensate collector may not be installed correctly to operate the interlock. The fan will run but not the compressor
Sep 05, 2015 | Haier Dehumidifiers
My 35 pint (42 54351) dehumidifier is only ~2 years old. It will not stay on, even though the basement is very damp. Is there anything I can do?
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit, set
the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Kenmore 54351 Dehumidifier
Lg dehumidifier lhd30 normally removes an almost full bucket of water from my basement every 24 hours. Now in July it stopped doing so. I get about an inch of water per day now. If i turn the control down...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
uni, set the control knob to Maximum.
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor may have failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot & solve the problem.
Aug 07, 2011 | LG DH305 Dehumidifier
Fan running..just not dehumidifying all of a sudden...Maytag+45-Pint+Dehumidifier+M7DH45B2 7 yrs old
Todd, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled model, set the humidity extraction level on Maximum.
level
in basement applications . Raising the unit up off the floor,
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity connenser sensor has failed. These things usually occur in units that are 5 years old or older.
I hope this helps you to troubleshoot and solve the problem.
Jul 09, 2011 | Maytag Dehumidifiers
Have had the Kenmore 54351 Dehumidifier for 2 years. I started it up recently. Had it run for days. Not a drop of water. How do I fix it?
It may simply be a case of 4 things: Any of which can cause the problem.
1. The air intake filter is dirty or clogged.
2. The humidity extraction level is set to HIGH. Lower it to 32%.
3. Obstructed air flow around the unit. You must maintain a minimum of 12" clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. This is true in basement applications and the unit will not function properly. Unless it's a Low Temperature unit. Placing it up off the floor on a sturdy table or counter top that can adequately hold the weight of the unit, plus a full bucket of water, usually solves that problem.
Worse case scenario, the compressor needs to be recharged with refrigerant gas. But, that doesn't happen that often.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Kenmore 54351 Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
Edison Dehumidifier
You didn't say what humidity range you have it set for, or how damp of an area it is dehumidifying. The one in my basement also never shuts off and we have it set for the lowest humidity (meaning we don't want any down there). If you think it should be shutting off you might want to get another Humidistat they are $33.05 at this link, http://www.appliancefactoryparts.com/search/partinfo.php?partsID=278698&modelsID=118670&typeName=dehumidifier
May 19, 2008 | Edison Dehumidifiers
Dehumidifiers Logo
63 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
