Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
NEW MACHINE HOT WATER ONLY - Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
  • olddakota Oct 05, 2009
    WHEN COLD WATER IS SELECTED ONLY HOT WATER GOES IN THE MACHINE
  • Obertelli
    Obertelli May 11, 2010
    Sorry, but that's not even a valid sentence, let alone an intelligible question. Please rephrase your question to make clear exactly what you're asking.
    Genius:
  • Bosch Master
  • 1,461 Answers
Make sure the cold supply is okay and connected ,,Could be faulty solononid valve...
Posted on Oct 05, 2009
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
Hot water will not run into top loading machine.
Is this a new install? Has it worked before and now it doesn't? Did you let it run long enough to confirm that there was ample opportunity for the hot water from your heater to make its way into the machine? If you turn off the hot tap and the only solenoid that is opening is the cold, then there is a problem with the machine.
Dec 27, 2014 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Simpson eziset 605 wont take in hot water
Hot valve in washing machine required. Part is between $25 & $60 STEP 1: unplug machine STEP 2: undo the 3 Phillips screws on top of machine the fold top console forward STEP 3: Undo hot tap,disconnect 2 wires running to hot valve,remove valve,fit new valve. STEP 4: Refit top console. DONE
Jun 17, 2012 | Washing Machines
Hot water will not run properly into machine, have
fit new hot water valve but check the flow from your fill pipe first both easy jobs
Dec 15, 2009 | Washing Machines
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
New Royal espresso machine
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Jan 25, 2008 | Saeco Royal Professional Espresso Machine
No hot wash
If you shut off cold water the sensor will send message to computerized box the machine will not operate. it shut down the machine.
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Machine not filling with hot water
First check the filters in the inlet hose and hot water pressure. Sounds to me like the hot water valve is faulty. Test the w/machine on a hot water cycle, if you hear a noise and its not filling it up with water,its a faulty hot water valve. Air pressure?? change the water valve and remember it has a little rubber boot on the old water valve, transfer this to the new valve,or go into option adjustment mode and change you wash temperature settings.
Aug 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
