Question about RCA M4208 MP3 Player
My player will not even turn on, press the power button and the player looks like it will come on then goes back to power off screen
    President:
  • 2,923 Answers
Here are the possible causes of the problem:
1. Bad battery
2. Loose wire connection inside.
3. Corrupted program.
If the player is still under the warranty, contact the manufacturer and have them repair the player for free.
Have a great day!
Posted on Oct 05, 2009
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
How to unfreeze mp3 player
I would recommend you to upgrade your device firmware.
This will fix the issue.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
Wont turn on screen remains black as in not on black and it stays this way even when plugged in
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
My sansa will not load to the main screen and i have tried to fix it even when i plug it in to computer i goes to same screen
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Mar 22, 2009 | SanDisk Sansa MP3 Player
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
Nov 13, 2007 | Audio Players & Recorders
Try Holding the Power Button for 20 sec for a Power Reset of the device Turn on the Player ,hold the Power button for 5 sec.
Oct 03, 2007 | SanDisk Sansa e250 MP3 Player
RCA M4208  MP3 Player Logo
91 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
