Question about Nokia 2626 Mobile Phone
How to connect packet data using nokia 2626,without bluetooth
Using nokia 5130
Posted on Apr 16, 2011
I am having nokia 2700 classic phone when i am connecting it to pc via bluetooth it is showing subscribe to packet data could you please help in this
actually it is connecting to net over your mobile as settings are not there in your mobile it shows packet data not available ...
Sep 18, 2011 | Nokia Classic 2700 Cell Phone
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
I have a nokia 2626 & i want to use it as modem with my pc please tell me wether it is possible or not, if it is possible then please tell me the requirements & steps for doing so..
Hi, sorry but it's not possible to use the phone as a modem as this has no packet data and can only be used for GSM, calling and texting only. If ever you need to use a phone as a modem, buy one that has 3G and GPRS.
Mar 13, 2011 | Nokia 2626 Mobile Phone
Not able to connect to internet through nokia 2626 mobile handset the problem says that subscribe to packet data first
Hello
You need to contact with mobile service provider to subscribe and install setting of internet in your mobile
Hope it will helps, do rate if so. Good Luck CMPTRLINK
Dec 12, 2010 | Nokia 2626 Mobile Phone
Gprs set up
To define how to use the service, select Menu > Settings > Connectivity > Packet data > Packet data conn. and from the following options:
● When needed - to establish the packet data connection when an application needs it. The connection is closed when the application is terminated.
● Always online - to automatically connect to a packet data network when you switch the phone on You can use your phone as a modem by connecting it to a compatible PC using Bluetooth technology. For details, see the Nokia PC Suite documentation.
Download free configuration settings such as MMS, GPRS, e-mail, and other services for your phone model at: www.nokia-asia.com/phonesettings.
Oct 17, 2010 | Nokia 5130 Cellular Phone
How to activate my GPRS?
Hi jovie_ceniza,
Select Menu > Settings > Connectivity > Packet data >
Packet data connection. Select Always online to set the
phone to automatically register to a GPRS network when
you switch the phone on. Select When needed, and the
GPRS registration and connection are established when an
application using GPRS needs it and closed when you end
the application.
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 07, 2010 | Nokia 2626 Mobile Phone
I am able to on packet data in nokia 2626 mobile pls help
Just Call Call Center Who Forward You The GPRS Setting Once Again then Automatically Your Phone Can Connect To Internet!!
Feb 06, 2010 | Nokia 2626 Mobile Phone
How do I connect nokia 6070 to pc ?
You need to download Nokia PC Suiton the system then while installing it will ask if it is bluetooth or data cable connection you want to use.
You either connect through Bluetooth or data cable to the usb port to your pc.
Good luck.
rate this.
Aug 18, 2009 | Nokia 6080 Cellular Phone
I don't know how to transfer data to my nokia 2626
No Bluetooth, IrDA, cable, or PC suite support. -That's what I got checking with Nokia support.
However I found  a "Nokia 2626" cable at a site, but I'd suspect it's just a Nokia cable and they just write there the model you are looking for without even bothering to check for compatibility. But I might be also wrong, so ask them if it's sure for your phone and for their refound policy, because when you order it, without opening the box you can read the manufacturer supported models and if it's there, you can return it when it won't work in the end either. So here is the link:
http://www.mobilephonecrazy.com/modeldetail/2626,data_suite_usb_with_software.htm?mk=Select+manufacturer...&menu2=&gosearch.x=71&gosearch.y=36
Basically you can transfer data using SMS, MMS, download from the internet using GPRS, and you can copy contacts/messages from a SIM card to the phone.
If you want to transfer stg from a PC to the phone, upload it to a filesharing site and download it to your phone with its built-in browser. Or try the cable I mentioned above.
Feel free to ask back if stg is unclear.
rate this fixya pls
Apr 16, 2009 | Cell Phones
About nokia 2626 data cable
I am sorry, Nokia 2626 do not support any sort of connectivity with the PC (USB cable, Bluetooth or Infra red), Only way you can have games installed is through GPRS, this is phone is GPRS comaptible so try your luck in downloading games from net.
Mar 23, 2009 | Nokia 2626 Mobile Phone
Nokia 2626 Mobile Phone Logo
426 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
