Question about Remington Electric Pole Saw
Have a Remington electric pole saw blade stops when you apply pressure to cut
  • 193 Answers
The drive sproket is stripped out. The small plastic gears inside the sproket are worn out causing your problem.You can order part 107713-01 from 1-800-654-8534
Posted on Oct 06, 2009
Stopped running
If the saw got bound in the cut it may have popped the breaker on the saw. Find and reset it
Jun 14, 2013 | Remington 111409 - 01 6" Branch Wizard...
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Need a new 10" blade for a Remington electric pole saw, who sells them?
Afternoon Lee;
Probably Oregon.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Remington; YourSawModelNumber; 10; All; All; All".
The Oregon part number can be used at a local merchant (no shipping and handling) or over the Internet.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 07, 2010 | Remington Electric Pole Saw
Conector from pole saw to chain saw
You provide no model number, my results may not apply to your saw,
I went here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Typed "RPS96" into the "Model #:" window, then clicked search.
  • Clicked the RPS96 - 8 Ft. Electric Telescoping Pole Saw "View Model" link.
  • Clicked "View Illustrated Parts Breakdown" I think you want item 7, 107551-01, Pole Saw Assembly
  • Clear the "Model #:" window; type “107551-10” (coupling nut) in the “Search for your parts by Part #:” window and click search. NLA (Internet search for “Remington 107551-01 also NLA at every site that lists it.)
  • There is also a part number "111304-01" (thumb latch) depending on the pole you have installed. It is NLA at Remington but appears to be available at "Master parts"
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=111304-01
Part #: 111304-01 Price: $9.60
Description: SPECIALTY PARTS: *KIT, BRACKET (DSSP-SH3) (REM-17)
If this is also NLA, try an Internet search for "Remington YourPartNumber". eBay may be your only source.
RemingtonPower has stopped production, Replacement parts are mostly exhausted. Eventually every part will be NLA.
I worked fairly hard to provide this answer. It is a very thorough answer and it is not fair to punish me if you are unhappy with Remington. Good Luck HTH
Lou
Feb 13, 2010 | Remington Polesaw Wizard
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Need a bar for a 10ich Remington pole saw
www.masterparts.net/remingtonelectricchainsaw. USE THIS SITE AND FIND YOUR CHAIN SAW MODLE YOUR BAR IS IN THERE. I BOUGHT A REMINGTON ELECTRIC SAW 2 YEARS AGE AND THE THING CUTS BETTER THEN MY GAS SAWS, LOVE THAT THING
Aug 10, 2009 | Remington Electric Chain Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Need new saw blade part no & size for remington model 104316-04
The part you will need is the 8SB. You can call Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps!
May 24, 2009 | Remington Electric Pole Saw
Have pole with 8inch saw and will it work for 14in saw
If you have a Remington pole saw, then no you cannot not get a bigger saw to fit the pole you have. The pole was only designed to fit and support the weight of the saw it came with.
Apr 23, 2009 | Remington Polesaw Wizard
Remington Electric Pole Saw Logo
191 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
