Question about HP Office Equipment & Supplies
Photo paper cannot print
The photo paper comes loose in the printer roller and it doesnt print
    Brigadier General:
  • HP Master
  • 3,614 Answers
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Posted on Oct 05, 2009
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
I am using Premium Kodak Photo Paper and selecting photo paper in the preferences which I have used successfully before, but have just started having trouble. It started by printing a dark band more than...
Hello. By the sound of it the paper is slowing down at the point were the dark band is. If you can pay close attention to the speed of the paper the entire print. If is appears to slow down, then feeds out correctly, there are two things to look for. The Paper could be sticking in the tray at that point or the rollers are loosing grip. It can also be a combination of both. Make sure no ink or dust has built up in the rollers and also make sure you dont overload the paper feed tray. This increases the bend of the paper through the rollers and can cause them to slip.
Other than this the rollers can be re-set or replaced but it is normally not economical to do so.
I hope this helps Regards GM
Apr 12, 2011 | HP DeskJet 952c InkJet Printer
I have a Brother DCP 195c and it wouldn't take in other photo papers! I tried to print using the free brother photo paper and it's fine but when I use other inkjet glossy photo, it wouldn't take in the...
Your glossy paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 11, 2010 | Brother DCP 165C Compact Color Inkjet...
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Photo paper stops feeding
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Nov 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Can print A4 but not photo paper
It looks like you have a problem with the pick up roller....try removing the roller and washing it with water dry properly and insert it back to place ..this is temporary fix.....and mite not work 2..u need to replace this roller....if it continues to trouble you
Oct 31, 2008 | HP PSC 1410 All-In-One InkJet Printer
My printer wont print on photo paper.
Is it worked in past? Have you contact the HP for this problem? Since most of All-in-one printer do not possess better print facility, so it is difficult to use this one for photo print..
Photo paper is thick and may be motor not taking complete load of it. Check out with the roller moving firmly.
Oct 27, 2008 | HP DeskJet F380 All-In-One Printer
55 people viewed this question
Seeker5211
Seeker5211
