Question about Kenmore Dryers
Dryer not drying on selected cycle for example 30 min
  • Kenmore Master
  • 7,482 Answers
Sounds like your problem is with the timer switch, you may need to replace it as they are not repairable.
Good luck,
I hope this helps
Posted on Oct 05, 2009
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
AUTOMATIC HEAT SETTINGS NOT WORKING PROPERLY
lg's have a dry sensor that senses the wetness of the load they are not that reliable.. and will shut down the machine does it work on manual timer? meaning set it on high for 30 minutes.. it will probably run the 30 minutes... I have had this issue with my lg and so I just use the manual settings cheaper than having a 300$ service call. Its a problem with the dry sensor on the lining of the drum...
Dec 09, 2013 | LG DLE5977 Electric Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
Wash cycle moves to drain whatever the setting
Float switch in bottom of machine activated (leak) or pressure switch (or bottle for pressure switch) blocked or faulty.
Jul 10, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
