Question about HP Deskjet 6940 InkJet Printer
Which lights for ink mean what? I know the triple is color, but there are 2 single lights and only one spot for black. It is full but the first light stays lit and it won't print.
    President:
  • 787 Answers
The left lamp is for color cartridge, the right is for black.If one of them blinking mean the ink cartridge missing or printer not recognize it.
Posted on Oct 05, 2009
How to wire tree seperate lights
Not sure from your description.
Copy following link:
http://waterheatertimer.org/How-to-wire-switches.html#triple
Add a comment for follow-up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 24, 2013 | Leviton 1755 Triple Rocker Switch Decora
Tip
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
on Jan 04, 2010 | Office Equipment & Supplies
I need to use color ink not black and i dont know how to switch from black ink to color ink help please
Right click on your printer and properties change your printing option to single color black.
Jul 20, 2011 | Lexmark P4350 All-In-One InkJet Printer
HOW TO REFILL
I love to give the answer for your question but we don't know which printer model you are talking ?
Following the the common procedure for refilling the Ink Cartridge
COLOR CARTRIDGE
BLACK CARTRIDGE
Jan 22, 2010 | HP Office Equipment & Supplies
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
If I have helped please rate my post...I will always do my best to help
Apr 09, 2009 | Office Equipment & Supplies
Lost manuel to canon powershot A630 and I wanted to know how to take a black and white picture.
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800) -
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) -
  • Drive (Single-shot, continuous, self-timer [2 or 10 sec, custom] -
  • My Colors (Off, vivid, neutral, sepia, black & white, positive film, lighter skin tone, darker skin tone, vivid blue, vivid green, vivid red, custom color) -
  • Flash exposure compensation (-2EV to +2EV in 1/3EV increments) - in manual mode you can adjust the flash strength in three steps (1/3, 2/3, full)
  • Metering (Evaluative, center-weighted, spot)
  • Compression
  • Resolution
- Lisa
http://www.dcresource.com/reviews/canon/powershot_a630_a640-review/
Feb 26, 2009 | Canon PowerShot A630 Digital Camera
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
176 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
