Question about Sport & Outdoor - Others
Battery is fully charged, propane full, furnace will not come on.
I'll figure it out, please take me off your email list.
Posted on Oct 06, 2009
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Replaced thermocouple pilot stays on but burner wont light
Make sure the gas valve dial is turn to the "on" position. Otherwise, I would need more info to answer this question fully.
Nov 17, 2015 | Empire Comfort Systems DV-215-SG...
Does it need propane to run the furnace or can it operate on electric alone. i have no owners manuel
Got here late...I am assuming this is for an RV. There are probably electric furnaces on some of the newer ones, however, an electric furnace would draw more power than most parks could handle, so the is answer is it probably needs to have propane. On your panel, or near your furnace, you will see a switch to tell the furnace to use propane or electric...if your furnace is capable of running on electricity.
Sep 30, 2015 | Cars & Trucks
2014 Heartland Fairfield 405fl (extendend stay) Suburban SF42-Q furnace Does anybody know of any Mobile RV Mechanics in San Jose Ca (Bay Area-South)? Our furnace blower fan went whacky and broke the cage....
Go to Bryantrv.com and click on the Service Manuals link. It sounds like he missed a wire hooking it back up. There are usually 3 wires, red for hot, connected to the furnace and also a small blue wire with a red stripe, another small blue wire connected to varying colors but comes from the thermostat and a ground, usually yellow. There is a relay on the fan side of the furnace and a thermal safety on the back side, under the burner. The fan gets it's power from this relay and the furnace will not run until the fan is turning. It's common for the relay to go bad but I've only had to replace on thermal fuse in the last 12 years.
Mar 16, 2015 | Heating & Cooling
How do I know when my lg 2 extravert 2 is done charging
The battery bars indicator at the top of the screen will be full and when fully charged the message will say battery fully charged, if you unplug the charger and reconnect and the battery is fully charged you will see this message!
Oct 18, 2014 | Verizon Communications LG enV Cell Phone -...
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
How I know my lg lsp 350t has full charged
When your lg lsp 350t is fully charged, it stops reading like it is charging. You can also turn off the phone and plug in the charger, once it is full, the battery meter will turn blue or show battery full. \but when the phone is on, the way you will know that it is fully charged is that the battery shows a full bar and does not charge anymore.
Hope this information helped.
Jan 14, 2011 | Cell Phones
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Nov 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Sport & Outdoor - Others Logo
24 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
