Question about Motorola Mobility RAZR V3m Cellular Phone
My phone has no bars whatsoever and the calls keep failing. It just started this morning?
  • 416 Answers
the razors have alot of hardware and software bugs......the easiest way to solve this would be to do a master reset by going to the security menu and selecting the master reset option and following the prompt. Make sure you bake up any info you wanna keep like ringtones contacts and pics. Bluetooth to another phone would be the most sensible option. If for some strange reason reverting to factory performance settings does not work it is possible that the antenna has worked itself loose. In this case you must remove the back panel with a small screwdriver after removing the battery and its cover. At the bottom you will see a clear shell with a copper node, this is the antenna. Remove is by prying up near the tabs on the clear housing. Make sure reposition the antenna within the housing and make sure the node snaps securely back into the copper "fork" receptor. snap everything back together and your ready to go........if you really dont want to have to transfer your data and do a master reset, try the hardware fix first.....theres is no way i can know for certain without having the device in front of me but one of those two is almost guaranteed to do the trick.
Good Luck and please rate this post.
Posted on Oct 05, 2009
  • 832 Answers
There's are problem with the power amplifier(PA) of your
cell phone. Go to the nearest service center for check
up for repair or replacement of defective part.
    Brigadier General:
  • 3,614 Answers
HI
It seems that your fone was not getting any signals from your network.. Try to switch off the unit and remove the battery and resit the sim on the slot, then try to put back all together and turn ON. Also try inserting another SIM if you still don't have signals, if the problems was still there, this can be a a problem on your network or your phone signal was failing and have to be check and repaired.
Hope this info helps
Can't make outgoing calls - At & T
Since you have tried resetting the phone and checked that you haven't barred calls (call your operator to make sure that your line is indeed not barring incoming calls). The only thing you can do now, is to take the phone to a service center (or any place that has the right flashing equipment)to get the firmware flashed.
Dec 21, 2007 | LG Prada KE850 Cellular Phone
I am using nokia 6120 classic...i want call barring option..
go to menu in your security setting there should be an option to bar call s usually default barring code is 0000 but it also depends if your network operator allows you to barr calls . Either try my first option should you fail contact your network provider
Dec 09, 2014 | Nokia 6120 classic Cellular Phone
My outgoing calls are barred how to deactivate it on my Samsung galaxy s duos
  1. Go to Apps through Home screen.
  2. Tap Phone.
  3. Tap the Menu key.
  4. On pop up menu select Call settings.
  5. Tap Additional settings.
  6. Tap Call barring.
  7. Tap Voice call.
  8. To disable call barring, tap each of the barrings types that you've enabled before.
  9. Enter your barring password. When you never change your barring password, then the default is 0000.
Apr 09, 2013 | Samsung Mobile Phone Galaxy Duo S S6102...
My LG KC550 model mibile suddenly looses signal and people are not able to call me though it shows signal bars on the screen. At this point of time I would even fails to make calls too. If I switch Off and...
I have the same issue, even worse, my alarm goes off too. So phone shows signal bars and alarm icon, but nothing works until I switch it off and on. This is starting to be a huge problem because I rely on that alarm to wake me in the morning for my job. I'm seriously thinking of selling it or destroying it
Sep 23, 2010 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Everything was fine in the morning and then around 8 am i tried to call and it keeps saying your call barring has been activated ? but i havent been fiddling with my phone please help
its basically service from network provider,they can barred call for many reason like payments issues, inactive sim, call to your service provider to unblock call barring service
Sep 05, 2010 | Nokia E71 Smartphone
Need to barr a number that keeps phoning me at early hours in the morning ive got an n97 and cant seem to solve this plz help!!
The easiest and fastest way to barr a number from calling you is to call your cell carrier and ask them to bar the number.
Good luck
Dec 28, 2009 | Nokia Cell Phones
Cant send text messages. Says failed call barred
cant send message and call its says its barred
Sep 27, 2009 | Pantech Matrix Cell Phone
UNABLE TO MAKE CALLS, CAN SEND TEXTS OK BUT CANNOT MAKE CALLS
Hi friend,
Could you tell me what prompt text appears on the screen when you dialling out? If there appear"failed to come online" or "emergency call only" or " call barring"?
If there appear the "failed to come online" or "emergency call only",this may be because the signal in your place is not good ,you may try to dialling in the open air.
If there appears the "call barring", you may have set the "call barring", just find the menu "call center" or " call setting" and choose the "call barring" and reset it,turn off it.
Besides, you can check the "network setting", may be you have set it under the condition " WLAN mode" or "WLAN only",if so,any number may not allowed to dial whatsoever, you may try to change it to the option "GSM" or "GSM preferred".
You can more information here: www.1010store.com
Sep 24, 2009 | Sony Ericsson W395i GSM Quadband Phone ...
SGH-E900 Call Failed
check you contracting conditions
Aug 24, 2009 | Samsung SGH-E900 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
282 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
