Kenmore 34612 Bagged Upright Vacuum
Problem for Kenmore 34612 Bagged Upright Vacuum
Pushing it feels like someone keeps pressing a brake
By BBQsmoker on Dec 22, 2007
Ok, I'm sure this may sound odd but I'll do my best to describe the problem. I have a 30612 which I think is very similar to the 34612. When I push it on the carpet or on the wood floor it feels like a brake is being applied on and off repeatedly. In other words, it's hard to push and then easy to push. In about a four to five foot push it will be easy-hard-easy-hard-easy-hard. Sounds goofy, right? This will repeat no mater what conidtion. It doesn't matter if the vac is on or off, or if the lower housing is released or not. I think it's either the inside diameter of the wheels have worn to a point that they are sloppy and twist out of alignment or the wheel shaft is not being held properly by the plastic dust housing (due to wear) and it allows the wheels to rub on it.
Anyone seen this before?
Comments:
Jul 27, 2009
- Had the exact smae issue. The wheels are rubbing on the base of the unit. This is due to wear of the wheel hub and slop on the two retaining clips that hold the wheel shaft. I was going to buy new wheels but they were a little pricey so I wedged a washer between the wheel shaft and plastic body. This placed the wheels further away from the plastic base and made it "push" like new. I can send a photo of you like. Just email me.
Best Solution
posted on Jan 22, 2008
Very Helpful)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1792 votes
Well what you said about the wheels could be the problem. But it also could be the belt, if it hasn't been changed, or is a few months old, it may have stretched so as not to turn the brush roll, whitch would make push hard. The brush roll is what will pull the vacuum, so if the belt is bad, or the bristles of the brush roll are worn down, they need replacing.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 34612 Bagged Upright
Questions and Unsolved Problems for Kenmore 34612 Bagged Upright
Do you recommend Kenmore 34612 Bagged Upright Vacuum?
Answer
Answer
how do I take this vacuum apart to fix the cord?
Answer
i have kemore elegance 12 amp upright vaccum,the preformance indicator light is on.the vaccum is not... (More)
Answer
When using the hose accessories, it's fine. But the it will not **** up the dirt from the upright... (More)
Answer
I have a Kenmore vacuum 116 34612. The belt broke and I don't know how/where to replace it. Can you... (More)
Answer
I have a kenmore upright bagged vacuum. I need to clean or replace the filter but I don't know... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , TX
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
