Question about Fuji FinePix J12 Digital Camera
The power button will not switch on. It refuses
The power button will not switch on. It refuses to spring back up Can you solve this problem@
Dyson 25 canister release spring
It should be placed behind the catch (button). If the button retainers are not broken off, just place it under the catch and snap it back into place.
Dyson Helpline:
1-866-MY-DYSON
or
questions@dyson.com
Jun 13, 2016 | Dyson Dc 25 Animal
Stuck power button
Try to clear any debris, use a little bit of silicone spray to free up the button, if that fails remove the cover and check the switch that's under the button. Sometimes the plastic button will break , wear out , that activates the switch underneath and doesn't "spring" back when pushed in, not resetting.
Sep 24, 2013 | HEWLETT-PACKARD Probook 4530S
Lasterjet m1212 nf MFP printer refused to print, it keeps initializating, how to solve it?
connect the printer directly to the walloutlet....
try with a different walloutlet as well....
then unplug the power chord from the back of the printer as well as other cables if it is connected without turning the printer off...
then press and hold the power Power cycle unit by switching the power switch off, wait for 10 seconds, then power on..
if it does not work then
  1. Turn the printer off.
  2. Press and hold down CANCEL and Start Copy buttons at the same time while powering on printer.
  3. Continue to hold down buttons until the control panel display reads PERMANENT STORAGE INIT.
  4. Release the buttons. Printer will return to Ready automatically
Hope this helps
Oct 29, 2012 | HEWLETT-PACKARD M1212nf All-In-One Laser...
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My tabled blocked and I can't do anythink, not even turn it off.
Hi Daniela_p446
The best solution I can offer you is too firstly hold the power down till it eventually switches off (if i refuses try to press the volume + and power buttons).
Then once off restart it by holding down the volume + button down button whilst pressing the power button, until a white screen appears (the system recovery screen). It generally takes about 5-45 seconds.
Use the volume buttons to then scroll up and down and the power button to select and option; select format system then reformat device.
Hopefully this will help and fix your Archos.
If it doesn't I suggest you return it to the manufacturer/seller (depending on when you purchased it) as it maybe a hardware failure if the system refuses to accept inputs.
Mar 03, 2011 | Archos 70 Internet Tablet
My epson stylus CX5500 printer is unable to be switched on even though it is connected to a power supply. Regardless how long I've pressed the button, the printer just refuse to come to life. How can I...
First Check the power source e.g. make sure: the outlet you are using has juice if not change over to a new outlet. Make sure all the connections and plugs are properly inserted. If the Unit still does not power up I would just return it etc.. Also try just pressing the button once quickly and check the manual for quick start up instructions. Hope this helps:)
Jul 24, 2010 | Epson Office Equipment & Supplies
Refuses to recognize ink cartridges
Apologies for not responding earlier, forgot all about it. Solved problem by switching printer on and off many times. It eventually recognized cartridges. Now leave it switched on.
Jan 07, 2010 | Epson Office Equipment & Supplies
My Toro Model 71188 with a Briggs 282707 12 hp refuses to engage the starter ( which tests fine ). I get no power to the solenoid coil. Ideas?
According to parts lookup, there are three fuses in the wiring harness. Check these first.
The seat switch connector might be a suspect.
NOT the switch itself, but the two-wire connector attached to it. (Red and Gray wires)
Try this:
Unplug the connector from the seat switch and look down into the dual-terminal connector.
If you see a small, square plastic "divider" between the terminals, read on. Remove it with pick or plier. (Don't worry about breaking it, we won't be putting it back in.) Located behind the plastic you will find a tiny torsion spring that is wound in a cross shape. Remove and discard that spring along with the plastic divider. Plug the connector back in and try to start unit normally.
If no divider is present in connector, head for the brake pedal switch. Have someone work the pedal and observe the metal tab the "Triggers" the switch-button. These tabs often get bent and do not depress the switch-button far enough for it to make contact. Bend tab as needed to ensure the switch is "made" completely.
If still no-start condition, Turn key to "RUN" (not start) and try the electric PTO switch. You should get a nice crisp "click" at the clutch each time you engage/disengage the switch. If no click, have the battery load tested.
Lastly, check voltage at the solenoid with key in "START" position. On this solenoid you should see two large wires and two thinner wires. We want to find the thin WHITE wire and test it for 12VDC. If voltage is less than 9.5 with key held in the "START position, replace the ignition switch and/or battery.
Hope this is helpful,
Dolf-
Oct 15, 2009 | Garden
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Fuji FinePix J12 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
