Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
I just changed routers. printers works fine wired to desktop. but laptop top shows printer as being off line
    Problem Solver:
  • 13 Answers
Is your printer wireless?
Posted on Oct 05, 2009
  • 13 Answers
In response to mgill153, yes the MFC 490CW IS wireless. I've recently run into the same problem with mine - the printer worked perfectly both printing and scanning through my old linksys router. However, I just installed a new D-Link router and, despite spending countless hours fiddling with the friggin thing, I can't get my computer to do anything with the printer. The printer finds the wireless network no problem and I've tried connecting using WPS (push button and PIN), and even tried manually entering the WPA key to no avail. The printer says it is connected to the network but none of my systems can print or scan with it (my windows pc's driver lists it as "offline"). I've assigned it a static IP so there is no reason I should need to reconfigure my drivers, and therefore it was no surprise that, after taking the time to reinstall them, I still can't print or scan. The printer works fine when using a USB connection and, link I said, it's radio does find the router's SSID (which is different from the old one). It just won't work with the new router.
Posted on Oct 26, 2009
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
LexmarLk X4850 fax wireless set-up
Printing: since Lexmark say you can either connect wirelessly or wired and not both, you must either connect your daughter's machine to the hub by wire or yourself to the printer wirelessly.
Fax: this will need a phone line.
May 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Compaq Presario 2232US. The printer on the Desk Top works. From the Desktop, I have 'shared' the printer. From the Laptop, (Compaq)under Control Panel, Printers, the printer Icon is there, however, I...
hi im josh, friend you need to set up network connection for printer config.becoz it is different connection from your internet.try to do so.good luck.
Feb 16, 2009 | Computers & Internet
Connection problem
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Jan 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
What router do I use for the hp officejet 6110 All-in-one
You should put both computers under the same "groupwork" name .
to change this settings right click on MY COMPUTER the go to properties
then the go under the COMPUTER NAME tab. CHANGE the settings Look at PICTURE #1
When you choose the "workgroup" name make sure that you pick a unique name.youll probably want to use your name.look at picture #2.after changes are done your asked to restart once you have done this FIRST part let me know i can help you with the setup of the Nwetwork Printer.b07620b.jpgbdecea2.jpg
Nov 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Network printing suddenly stopped working
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Jun 02, 2008 | ASUS WL-500g Wireless Router (WL500GDLX)
Brother mfc 665cw connection error
I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
3 weeks ago installed netgear rangemax router along with a gateway laptop com. also a H.P. printer wireless. eveerything was working fine now printer will not work wireless and i canot get into my router...
Try the reset switch on the back of the router. Using a paperclip, hold the reste switch in for 30 secs and then power down the router. Once that is completed, you should be able to access the router config page under factory settings.
Mar 14, 2008 | Computers & Internet
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
453 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
