Question about Intel Motherboard
Front audio ports not working.
I can't seem to get the front audio ports working. I have been through the bios and made sure that audio is enabled. This is a new mobo. I have used front audio hardware from a working computer, ruling out any issues from the mobo to headset.
  • 7wolfman11 Dec 29, 2007
    It's a Gigabyte mobo, no jumper pins to enable front audio. My system uses Realtck HD audio and I found out that you need to disable the front audio ports in the sound software to get the ports to work, one would think you need to enable them but not in this case. So problem solved.
How do you disable the audio on the motherboard and make pc recognize new sound card? If anyone knows the answer please send to my email. thanks. Joe
xmarinejoe@yahoo.com
Posted on Feb 09, 2008
  • xmarinejoe Feb 09, 2008
    I do not have the user manual. It's the p5b motherboard. A friend built the computer for me and I am unable to get in touch with him. I believe that the entire audio device is bad because Media Player is unable to play music. It says something about "no sound present." I bought a regular sound card and installed it but need to disable the audio on the motherboard before the new drivers will take for new sound card. I know this sounds confusing, but any help will be greatly appreciated. Thanks
    Joe
    Sergeant:
    Champion:
  • 243 Answers
What motherboard is it/ Normally there are jumpers that you have to move to select wether rear or front audio is used. Should be in the user manual. :)
Posted on Dec 29, 2007
GTS 450 vs gigabyte ga-g41m combo
Male sure you have the latest audio drivers installed and there are no errors through the Device Manager, The latest audio drivers can be found in the "support and download" section for your motherboard (http://www.gigabyte.com/products/product-page.aspx?pid=3997#dl). If this doesn't help double check your connections and if possible use another computer to make sure the speakers you are using are working.
Nov 06, 2013 | Computers & Internet
Hi! no sound?! WinXP Prof 2002, MB P4TGV, In Bios Audio Enabled, There all drivers in Device Manager, In Control Panel in Sounds and Audio devices everything faded and "No audio device".
I know this isn't your exact motherboard, but this may help you in some way. Just to make sure the jumpers are set up correctly for the front panel audio. Click HERE and go to page 11 to see the jumper settings. You can also try to do a "Scan for hardware changes" in Device Manager. From what you have written, it seems to me that it's something to do with the audio in the bios, yet you say it's enabled. If this is a problem after installing a new program or operating system, it could be that the new software is to blame.
I hope this helps. let me know if there is anything I can do to help you further
Joe
Sep 02, 2011 | Biostar P4TGV-R (U8668DCOMB7) Motherboard
Front mic & audio sound no come
The cable is disconnected that goes to the front ports.
Check the device manager and make sure there are no yellow exclimation or red question marks at any devices.
Look in the BIOS to make sure the front ports are enabled as some machines have a setting in the BIOS to turn on and off front panel ports.
I hope this helped.
Good luck and have a fantastic day.
Jun 22, 2011 | HP Compaq dc7600 Small Form Factor PC...
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
I am using g31 mb my front audio not working, but back audio working fine. i checked cable and everything but same problem.
Hi
Check your bios settings for any front panel port settings and make sure it is enable.
Also check for the audio jumper settings. Refer to the motherboard manual.
Hope it helps..Thanks for using Fixya.
Apr 01, 2010 | Gigabyte Matx Intel G31 775 DDR2-800...
Need front usb motherboard configuration
You dont need to configure any usb ports if the usb ports are enabled in BIOS all the usb ports will be activated automatically(front and rear). If still you want to check, go to BIOS and check if they are enabled.
Oct 04, 2009 | Computers & Internet
Audio sound problems
to enable REAR green audio port,there needs to be jumpers between pins 5-6 and 9-10 of J2 which is towards back PCI slot area.If the jumpers are not present, the front panel audio is enabled.
Jun 27, 2009 | Computers & Internet
ATI Radeon HD4850 512MB GDDR3 with
you have to go into control panel hardware and sound, now click on sound, you will see speakers with a green check next to it. on top you will see HDMI enable those and hit test button. this is part of device no worry bout bios or motherboard. Just make sure you use the adapter that came with the video card it will only work with the supplied adapter. Not a dvi to hdmi cable. this will work. i hope this helps and good luck. I can coach you more but i am not sure of your operating system. i was coaching you using vista.
Feb 21, 2009 | ASUS EAH4850/HTDI/512M RADEON HD 4850...
No sound produced
may be the drivers are not installed or there may be some problem in the speakers pin which you insert it to the audio port or you might have connected to the wrong port( you must connect it to the green port) or the audio device might have got disabled in the bios settings just go to bios (by pressing F2 at the time of booting)
& check it if the audio device is disabled or enabled ....
if it is disabled then just make it enable .....
these are all the possibilities just have a check with these basically .....
if these are seem to be correct then there is only one last chance the capacitor near by the audio port is burnt out so just open the motherboard & check it is there any burnt mark or smell ...(something there will be no burnt mark )
after this just have a check that the audio device pins are connected to the motherboard header or not there will some small 10 or 9 different pins which must be correctly connected to the header .if they are not connected then also the audio doesnt work ......
if the capacitor is gone then you must get it replaced by the motherboard technician ....
just by having the check with these your problem will be solved
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 06, 2008 | Compaq Computers & Internet
Audio sound
any doubts reply me
thank you
bye
just refer to the
Jul 05, 2008 | Mercury P4VM800M7 Motherboard
Intel Motherboard Logo
169 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
