Question about Kenwood DPX-4020 CD / Cassette Player
My Kenwood DPX-4020 suddenly turns up to max vol
My Kenwood DPX-4020 suddenly turns itself up to maximum volume and stays there. It won't turn off. No button on the device gets any response. I end up having to pull over and yank the fuse out of my fuseblock just to stop it. Reinserting the fuse seems to allow it to reset to normal but it only stays that way for a little while. I can tell by the feel that the volume buttons are okay. I know what a collapsed blister panel-mount button feels like but this isn't the case. Both volume up and volume down buttons respond with a crisp return.
All off kenwood dpx-4020
Posted on Nov 29, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Posted on Oct 05, 2009
  • RAYDOG Oct 14, 2012
    how do replace it DIY ....
Hi i have a kenwood hdv 910 car sterio and i do not have the code key cod for it.
you can send your stereo back to Kenwood to have the security code reset.
Oct 19, 2008 | Kenwood Car Audio & Video
Kenwood dpx 5200m
software hang, only way is reset.
Feb 03, 2014 | Car Audio & Video
All buttons of my kenwook dpx 4020 does not respond. I tried to press the reset button but that does not respond too
all buttons of my kenwook dpx 4020 does not respond. I tried to press the reset button but that does not respond too
Oct 03, 2011 | Kenwood DPX-4020 CD / Cassette Player
My Kenwood DPX-4020 suddenly went "dead". No power whatsoever on the led's and nothing happens when i push any/all of the buttons. I have it reset many times, checked the wiring's and fuses at...
1st you need to check the fuse in the fuse panel in your car to see for some reason the radio fuse is not blown . if is change it . if not take your radio out and see if fuses for radio is blow on back of radio then some have a fuse on the red wire check fuse there too. if nothing buy a digital volt meter and start checking your ground wire to see if it broke . take volt meter turn on dc volts put black test lead on your radio ground then take the red test lead and and start touching the yellow wire to see if you get a 12 volts on meter if you get 12 volts ground is good ... then check the red wire turn on the ignition switch and put the red test lead on red wire and see if you get 12volts if nothing
either you have bad ground or you have a fuse blow in car some were .. if you can't figure it out call a local mecp certified shop and have them look at it ....
its possible that the radio is just died and you need to buy a new one electronics dont last forever when you use them daily ...
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | Kenwood DPX-4020 CD / Cassette Player
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
Kenwood dpx 4020
The iPod will stop itself from charging when the battery is full, and will not overcharge. I'm pretty sure you can't disconnect the power to the iPod (would stop it from charging) and still use the Audio to your stereo.
Aug 19, 2007 | Kenwood DPX-4020 CD / Cassette Player
Kenwood DPX-4020 CD / Cassette Player Logo
248 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
