Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
On Homelite chainsaw model 410, where is the fuel filter located, in fuel tank or carburator?
    President:
  • 2,220 Answers
In the tank on the free end of the hose. HTH
Lou
Posted on Oct 06, 2009
    Sergeant:
  • 302 Answers
The filter is in the gas tank. Fish it out with a piece of wire. hope this helps you
Homelite chainsaw model ut10580a
First place to start is replacing the fuel filter in the fuel tank, hook the hose out through the open filler hole with a piece of bent wire, replace the filter on the end.
May 07, 2013 | Garden
When I stored my pioneer chain saw last year, I forgot to empty the fuel from the tank and the carburator. Now it won't start. What should I do? Louis
GO TO YOUR LOCAL RURAL KING AND PURCHASE SOME ..."LUCAS GAS TREATMENT FOR CHAINSAWS"... TO CLEAN THE STALE GAS IN YOUR CHAINSAW.
HOPE THIS HELPS!
Sep 06, 2011 | Homelite Garden
Where is the fuel filter located on model ut20024b string trimmer
Hi, inside the fuel tank. You can hook it out using a piece of single strand wire. Hope this helps, regards Phil.
May 25, 2011 | Homelite Garden
Run on choke but willnot run when choke is off
U need to clean the carburator and empty old fuel out of tank 2 cycle gas gums up over time clogging ports in carburator also check fuel filter
Dec 11, 2010 | Homelite Garden
Homelite 240 will not continue running
Check the fuel filter stone in fuel tank. Replace it with new one.
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
On a homelite chainsaw model d3300 i have all fuel lines lose and have forgotten location of where they go. What is the locations of the supply lines from the gas tank to the carburator?
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Feb 23, 2009 | Homelite Garden
Old homelite chainsaw, wont pull fuel
most of the time there is a air leak in one of the two crank shaft seals.to get to them you need to pull off the flywheel and the clutch assy.look for wet areas. that will be where the seal is letting out the oil and air.If you keep putting starting fluid in the carburator you will burn the rings,the piston and the cylinder up
Dec 26, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite chainsaw carb adjustments
bear973 you must make sure that that in tank filter is seated in right position and not just floating around inside the tamk
Oct 05, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
339 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
