Question about RIM BlackBerry Curve 8310 Smartphone
My phone will not come on. When I plug the charger up, the indicator light comes on for about 3 seconds then goes off. I have tried using another persons battery but my phone will still not come on. What can I do?
    President:
  • RIM Master
  • 2,923 Answers
You need to contact the manufacturer of the phone. There's a bad component that needs to be replaced.
If the phone is still under the warranty, take advantage of it and have them repair your phone for free.
Have a great day!
Posted on Oct 05, 2009
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
My nextbook 7 will not charge. When I plug in the charger it would begin to charge for a dew seconds and then the charge will drop. I thought that maybe it was the charger, so I tried the charger on...
Is there an indicator light that comes on when the charger is plugged in. If so, does it stay on. If there is and it does then there may be a problem with the battery. If there is a light but it goes off when you wiggle the plug when it's plugged in, then there may be a broken connection inside where the charger plugs in to the socket.
Jan 02, 2015 | Tablets & eReaders
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
Battery power was very low. plugged Drsire into charger and set phone to shut down mode. when i unplugged it from charger and pushed the 'on' button,the phone vibrated 3 times but will not turn on.have...
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Many thanks for using FixYa
Nov 27, 2010 | HTC Desire Cell Phone
Charger light indicates charge but goes out after a few minutes
Hi
thank you for your query
Please can you try the following
1) remove battery and charger
2) Press and holdpower buttone down for at least 20 seconds
3) Plug in charger only and then power thelaptop on, once windows has loadedup, plug battery back in and then allow to charge, and see if the fault re occurs
I hope this helps
Regards
Shauqat
Sep 24, 2010 | Acer Aspire 7720 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
WHY WONT MY 7280 CHARGE OR TURN ON
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Jun 04, 2008 | RIM BlackBerry 7280 Handheld
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
132 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
