Question about Nikon COOLPIX L18 Digital Camera
I'm getting an era message saying, ''The Scanner or Camera is in use... please try again later...'' What does that mean?
When calling someone i get no dial tone utnil i put it on speakerphone. when call connects it says it is forwarding. also when trying to use camera it says busy try again later.
That means your buzzer speaker is bad. You will have to get that replaced. When the camera says it's busy you will have to get the camera replaced. It may also be a loose connection internally. I have repaired quite a few with this issue.
"Please leave me a feedback or testimonial if this helped you,Thanks!"
Oct 27, 2010 | Motorola Mobility RAZR V3
Can't download pictures
Two suggestions:-
1) Go to the Canon website, follow links to Support/Downloads and see if there's a firmware update for you camera. Check if there's a forum where someone else has had the same problem and resolved it. Finally, use their "Contact Us" facility to see if they can offer a solution.
2) It doesn't resolve but it should get round the problem and that's buy a universal card reader.
Apr 09, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Trouble downloading pics from my Coolpix L100
Are your batteries fully charged? Direct Camera to PC transfer uses a lot of power. Some early L100s could not use rechargable batteries - unless you downloaded new firmware fron Nikon. That needs a card-reader. Once you have a card-reader, use this to download the pics, so that the PC supplies all the power.
Nov 01, 2009 | Nikon COOLPIX L100 Digital Camera
Wont take pictures says memory card era but i replaced the memory card
format the memory card in standard ( FAT)mode into your pc ....and try again ...also try to clean the plug and the card for any dust or so ....if the card is not the original one ...see if the camera specifications includes this card model and size as a compatible one ...there is the posibility that you used the card for something ...and the data on it are not being readed by the camera ...so ...try to format it clean ...
May 30, 2009 | Canon PowerShot S2 IS Digital Camera
When i am on msn and want to put on webcam a message appears in a conversation saying Messenger is not available right now. Please try again later. (0x8ac70202) MSN on't let me use my web cam in a...
This issue has been determined to be caused by a compatibility problem with Windows Live Messenger 2009 and the McAfee Site Advisor. McAfee is working on a patch to address this issue, but until it becomes available, you may try the posted workaround on their website at: http://service.mcafee.com/faqdocument.aspx?id=TS100601
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Canon A460; Downloading pics to computer
I have the exact same camera and all I did to put my photos on the computer was plug my camera into the computer using the USB cable provided. A wizard window should pop up and click on import photos. If that doesn't work, then I'm not sure what to do. I have windows Vista, by the way.
Dec 26, 2007 | Canon PowerShot A460 Digital Camera
Unable to download photos from Canon 350D
when downloading from my EOS 350D I get the message
'Camera launcher exe has stopped working'
I have Vista Home Edition
I am getting desperate to find a solution!!
Dec 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Picture problem
is your computer connected to scanner?? if so remove the scanner and deactivate the scanner software in computer then the problem will not come.
Nov 18, 2007 | Canon PowerShot A95 Digital Camera
Scanner
Uninstall then reinstall the drivers.
Sep 20, 2007 | HP Officejet J5780 All-In-One InkJet...
Nikon COOLPIX L18 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
