Question about Peachtree Woodworking 12' LEFT READING STEEL TAPE MEASURE
How to read steel tape? - Peachtree Woodworking 12' LEFT READING STEEL TAPE MEASURE
    Scholar:
  • 75 Answers
Not enough info, a steel ruler could be in 64's of an inch, a steel tape measure is usually in 16's of an inch but some are in 32's of an inch until you get past the 12" mark.
Posted on Nov 06, 2009
My K & E 100' Favorite Wyteface tape will not rewind. This is such a beautiful device and I hate to trash it. There are no visible screws holding the shells together. The shells are leather with a steel...
most tapes have a single screw under the belt clip that holds it all together. You will have to pull it apart to replace the broken spring on the end of the tape.
Aug 09, 2013 | Measuring Tools & Sensors
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
LTO tape Drive keeps ejecting tape
This could be that you are putting an LTO3 or LTO4 tape in the drive (or expired cleaning tape) Or it could be that the tape or tape drive has a problem reading the data.
Try using a brand new cleaning tape (clears the cleaning issue) and then try a brand new LTO2 tape.
If this works, then the issue was just related to your tapes, if this does not work then there must be a problem with he drive itself.
If the problem is with the drive, then contact www.tape-drive-repair.com for replacement costs. These drives are now very inexpensive and it might just be easier to replace the drive.
If you want to attempt to fix the issue yourself then respond back with a few more details and i will try and advise you on the best things to try.
Sep 07, 2012 | Dell PowerVault 110T LTO-2 Ultrium Tape...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
What indicates the black arrow mark in 16inches,32inches,64inches in steel measuring tape
Typical framing is laid out on 16 inch centers. Example: the studs in a framed wall are 16 inches apart which gives the required strength and allows drywall to break at a stud when it is installed. Drywall sheets are 8 foot or 12 foot, if the framing is on 16 inch centers then the drywall will end at a stud. The tape measure is highlighted at multiples of 16 inches to make it easy to mark the studs when laying out the framing.
Jan 17, 2011 | Peachtree Woodworking 12' LEFT READING...
Tape insertion problem
Now It needs mechanical adjustment, and your camera work fine again.
Thanks
Mar 03, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
My VHS is not reading the tape it was working fine before. i inserted a video tape and it started making a loud sound and it was not reading the tape then when i took out the video i noticed the tape was...
Take the top cover off & have a look on the right hand side of the deck when your tape is playing. Is the tape riding up when it meets the pinch roller ( a small black roller on the right side)? If so the roller is either dirty or worn & would need to be replaced, this will cause your tape to crinckle & damage the tape.
Aug 12, 2009 | Panasonic Televison & Video
FINE TUNING TAPE FILES
No. That's the problem with tapes. Time to move to magnetic or flash media
Aug 07, 2009 | IBM (09N0733) Tape Drive
Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
May 23, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
Peachtree Woodworking 12' LEFT READING STEEL TAPE MEASURE Logo
337 people viewed this question
Top Peachtree Woodworking Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Peachtree Woodworking Measuring Tool and Sensor Expert? Answer questions, earn points and help others
