Question about Toshiba Tecra 8200 Notebook
Usb does not recognise external hard drive
My usb ports do not recognise external hard drive Th following message is displayed
"This usb device can perform faster if you connect it to a Hi- speed USB 2.0 port"
  • 922 Answers
Your drive is being recognized. However, your computer only has USB 1.1 so you are being notified that USB 2.0 is faster. This message is FYI and will not prevent you from accessing the drive.
After you see that message you should see your external drive in "My Computer" If you don't see the drive you probably need to assign an available drive letter to drive.
Open Windows Help and Support.
Search for "drive letters" and find "assigning drive letters"
This will walk you through the process.
If this helps, please vote for my solution.
Posted on Oct 05, 2009
    President:
  • 1,187 Answers
It is being recognized.
[My Computer]
It is probably Drive E:
The USB port on your laptop is a standard 1.1 version. Your ecternal drive will operate better in a USB 2.0 (HiSpeed).
Try all your USB ports. If you have a USB mouse/keyboard, or other USB device, remove those and test the drive there, too.
  • 329 Answers
Try using all available USB ports......or install chipset driver of laptop...do reply back
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
My Maxator hard drive is plugged in and I got a message on the screen saying the "Hard drive has malfunctioned and is no longer recognised by the computer". The light was on, then blinked a few...
plug the hard drive into a different usb port, or take it to a friends computer and try it there, if it works the problem is in your usb ports, these issues are hard to solve, but first make sure the drive is actually ok
Mar 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
Dec 14, 2009 | Computers & Internet
External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Aug 18, 2009 | Hitachi 0A52126 120 GB SATA Hard Drive
My hdd 250gb external drive has stopped being recognised by pc
make sure the usb function of mb is enable in biose suyyam@gmail.com
Jul 22, 2009 | Iomega 33089 250 GB Hard Drive
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
IOGEAR COMBO not recognised
Is your hard drive detected by the computer? Did you try changing the USB ports? You can check if the drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your drive. If you dont then the drive is probably not detected. If you see, you can just re-format it from here and it will appear in your my computer.
Dec 21, 2007 | IOGear COMBO ION GHD135C160 160 GB Hard...
Toshiba Tecra 8200 Notebook Logo
492 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
