Question about Reddy HEATER RLP30 30,000-BTU PORTABLE LP PROPANE FORCED AIR HEATER
Looking for a thermocoupling for a Reddy propane heater
  • 232 Answers
Reddyparts.com has most of the thermocouplers.
Posted on Oct 06, 2009
Testimonial: "Thank you for making my search for my heater parts. I will use your service again"
I have a propane PRO 100 Reddy Heater. It will ignite, but when the switch is released or the flame goes out
sounds like maybe a bad thermocouppler or the thermocouple needs cleaned....
try that repost if anymore problems.... the thermocoupler will be next to the flame usually a copper piece lightly clean with some sand paper...
Jan 08, 2011 | Reddy Heating & Cooling
I have a PRO100 Reddy Heater would not stay lit when you release the ignite button. I replaced the thermocouple and it did nothing. What else could be the problem besides the valve?
I had the same problem. Heater was propane with a long hose for movement.
I put the heater on my garage work bench and the thermocouple tested okay.
Tried to restart and it ran like a champ. Reassembled bottom panel, retested great.
When I set it on the floor, it went out! Hmmmm.
Restarted back on the benck. Great. No good on floor....Very cold (28 F) in the garage.
Think the propane might be going liquid in the hose...when heater hose has a "drip loop"
it works fine.
Maybe this is nuts, but it works keeping the heater up a bit on a STABLE surface.
Jim
Dec 17, 2010 | Reddy Heater RLP100 Portable Forced Air...
Gas flow
sounds like a ad thermocouple.
Jan 18, 2010 | Reddy Portable Forced Air Propane Heater...
Reddy Heater will not stay lit
Thermocouple it going bad had same problem, you Should replace it.
Jan 03, 2010 | Reddy Portable Forced Air Propane Heater...
I have the pro reddy 100 LP. It hasn't been run
replace the thermocouple anyway,it will go bad after time
Dec 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
I have a rllp35a propane heater and it will ignite
either the thermocouple is bad or the pilot flame is not hitting the thermocouple .if the flame is hitting the thermocouple correctly it is most likely that it is bad and needs to be replaced
Mar 01, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Nov 29, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
226 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
