Question about Braun M880 280 Watts Hand Mixer
I have brown hand mixer . hand mixer's switch is
I have brown hand mixer . hand mixer's switch is hang and mixer not stop. the switch is not working on off please help me . i stay in pune please give me number of workshop for servicing
  • Anonymous Mar 16, 2014
    hand mixer need board for GEhas on off switch don't work board has rates of speed buttons need board
  • 832 Answers
Just buy the replacement switch, buy a star or philips
screw driver and do it yourself. Just copy how it is mounted and get it done. Just e-mail to us the result.
Posted on Oct 05, 2009
Mixer stop working powerless
Does it work on liquidy content? If it does the reason for not working could be the mixer too thick for its power and may burn motor.
Nov 07, 2013 | Black & Decker 175 Watts MX150 PowerPro ...
The mixer stops running while mixing. You can hit the head on it with the palm of your hand and it would start running again for a minute or two and then stop again. It is getting harder to get running as...
It sounds as though you have a loose connection, probably either at the switch or the motor. Unplug it and look at all of the connections for looseness or signs of burning. Good luck.
Feb 27, 2010 | KitchenAid KV25G0X Stand Mixer
Mixer shuts off when I whip potatoes
It apparently has a thermal overload switch . When it warms up it shuts off.. Only remedy is to buy instant potatos. Just kidding, the thermal switch needs replacing.
Oct 27, 2009 | Food Mixers
My mixer will only run on high speed. The other two speeds (low & med.) do not function
check the warranty? it may be still covered, sounds like a replacment switch/unit required.
Aug 16, 2009 | Braun Food Mixers
My handmixer suddenly stopped working while i was
sounds like the beater is not all the way in or it broke a gear
Mar 12, 2009 | Braun M880 MultiMix Hand Mixer
Hobart H600 wont shut off
Sounds to me like the start switch contacts are welded shut.If you have a multimeter set it to ohms,remove 1 wire from the switch,put your meter leads across the switch and if you get a reading that switch is bad.If you dont get a reading i would check the side switch on the contactor.Im a hobartt tech and repair these mixers alot.Let me know.
Feb 11, 2009 | Hobart H600 Stand Mixer
Parts for mixer whisks
need beaters for blck & decker mx230 hand mixer
Aug 16, 2008 | K-Tec Food Mixers
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 04, 2008 | Hobart A200 Stand Mixer
Bottom Slide Cover (Part 2a in the manual)
See the description for the speed problem and repositioning of the slidere at this link. The slider should snap back in place easily if everything is ok. The slider also operates a switch inside the mixer. This switch is intended to only allow you to run on full power when using the hand blender. You may need to open up the mixer to check this switch is not stuck in the activated position permanently. Otherwise consider the description of the speed problem in the link.
Jun 17, 2007 | Braun M880 MultiMix Hand Mixer
Braun M880 280 Watts Hand Mixer Logo
175 people viewed this question
Top Braun Food Mixers Experts
Slo Mover
Tom Chichester
ray gallant
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
