Question about HP DeskJet 840c InkJet Printer
How to check whether the black in k cartidge is
How to check whether the black ink cartidge is defectiveafter it was refilled
  • 708 Answers
If its defective it wouldnt print or you would get an error message. If you are having quality concerns then the print head is probably clogged. Nothing you can do except replace the cartridge because it has the print head built into it.
Posted on Oct 05, 2009
I cant print anything frm hp f4288
hi
you have a bud refilling process
check here how to refill right fro black
http://www.youtube.com/watch?v=MPi2GqJg5QM
for color http://www.youtube.com/watch?v=C6-N-Pxmjxk
Mar 06, 2010 | HP DeskJet F380 All-In-One Printer
Not printing in black
if u r used hp all in one or another then don't use duplicate ink cartidges. let make possible for u for using. boil a half glass of water, not too hot then after that drop the cotton in normal hot water & then clean the cartidge with this silly cotton on there when cartidge supply ink to printer, after some time get a wet cloth or cotton & clean it with wet clothe & adjust t=in the printer. i m sure ur cartidge will work. if ur problem not get solved then call me any time on my cellular no. +919876388918, i will try to solve ur problem with different way.
thanks alot,
sanjeev .
Aug 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Hp f4288 all in one black cartridge( N0.818) refilling method
when i fill this cartidge after finishing the cartidge is not printing why?
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Jan 23, 2008 | Lexmark Z1420 Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Printer is not printing black
Remove cartridge and remove the mains from the wall.
Try cleaning the contacts with a cloth dampened WITH WATER, wipe it up with another cloth and let dry.
If your old cartridge is not working again, try with a new one, generally is the cartridge which may become damaged, not the printer... hope !
Dec 31, 2007 | Lexmark X1150 All-In-One InkJet Printer
Black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
Oct 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon MP780 didn't report out of ink and now will not pring blanck
Have you tried cleaning or aligning the heads? Were the first cartridges refills? when an ink cartridge is refilled (depending on the model) the printer needs to be tricked into thinking a "new" cartidge is being installed. You may need to check the owners manual to see if the is the case. I have had to use tape to block off certain contacts, then remove the cartidge and block off another section of contacts, then remove tape all together and re-insert the cartridge.
Jan 27, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP DeskJet 840c InkJet Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
