Question about Hoover Vacuums
Replacing a belt Hoover wind tunnel - Hoover Vacuums
  • 294 Answers
You will find four screws under the bottom cover. remove these. remove the beater bar, loop new belt on bar on pulley area. install the bar and then pull the belt over the motor shaft. re-install cover.
Posted on Oct 11, 2009
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 16, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacement belt # for hoover wind tunnel model u5750-900. original belt # 38528-035, please
your belt number is correct ending in 035. I have had luck with belt number ending in 033 also.
Jan 28, 2009 | Hoover U5750-900 WindTunnel Bagless...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Wind Tunnel
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Mar 09, 2008 | Vacuums
Vacuums Logo
116 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
