Question about Nokia 1100
Cannot download music from my pc to lg cell phone
After connecting a usb cord , the application always allows for a certain download . the results are always failed atempts
  • lamarshan Mar 29, 2008
    I cannot sanctionize music from my computer to my SGH Z650i (via) usb cord. Can anyone help me?
  • Anonymous Jul 07, 2008
    When I try to download music to my fusic LG from my computer it says no file
  • 137 Answers
Lg is a difficult cell. Check if you got the correct cable for correct cell, Check inside the connector where you plug the cable in if you didn't damage some connector pins, because some people sells cables that does not work on lg cell and damage the conector pins when you plug it in. Ps Did you loud the drivers for your cable, and is it usb or serial cable.
Posted on Dec 22, 2007
I need music to listen to. Where and how to put music on without WiFi or internet
Can you play music on your cell phone? I have 412 songs on mine I loaded them all on my cell with my computer and a USB cable connected to my phone. I have an application from the phone's website(LG) in my case. It allows me to get music , pictures and video on and off my phone. Way easier than trying to load it with blue tooth . Try going to your phone's website to see if they have the software to do it.
Nov 16, 2015 | Cars & Trucks
LG Optimus M+ add music
Hello William,
To transfer files using USB devices
  1. Connect the LG OPTIMUS M+ to your PC using a USB cable.
  2. If you haven't installed LG Android Platform Driver on your PC, you need to change the settings manually. From the Home screen, touch the Applications Key Settings > Connectivity > Default connection mode > Mass storage only.
  3. You can view the mass storage contents on your PC and transfer files.
Dec 06, 2013 | LG GT540 Cell Phone
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached:
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
How do i down load music from my pc
go online wherever you got your phone from and it will say download movies or download music and stuff like that
Nov 10, 2009 | LG Lotus Cell Phone
My compter does not regonize my LG Dare or Sd Card? How can I sync music to my LG Dare with the software. My carrier is Telus and I did not get the cd with any of the downloads to do so?
In order for the phone to work with ur pc u have to set/change the connectivity.
Go into Phone settings, then Connectivity, then USB Connection Mode, then select either Mass storage or Data Service, to use Mass Storage you must have a Memory card inserted into the phone, then you can select mass storage and use your phone as an external hard drive/memory stick. In this mode u can only transfer pics, music, videos etc from pc to phone and vice versa via your Computer Windows Explorer.
It will not enable you to use the LG PC suite Application. To use the LG PC suite, you must select Data Service, then connect your phone to the PC via a USB port.
May 13, 2009 | LG RUMOR Cellular Phone
How to install java application in LG KG320
LG KG320 does not support install via USB, but you must download java applications or games via wap (GPRS).
Mar 16, 2009 | LG KG320 Cellular Phone
PC does not recognize Micro SD Card in LG CU500
The easiest solution is to leave it as 'mass storage', then navigate to it, my computer, mass storage, ect, Then just right click & open it. Now open your pictures, music ect. on your PC, drag & drop to the phone. That's how I do mine. You will be able to drop them into whichever folder you want. You might have to drop them into a folder on the phone then copy & paste them to the SD card after you disconnect from the PC. If you have more questions leave a comment, I'll be happy to help. Good luck.
Feb 25, 2009 | LG CU500 Cellular Phone
I cant load music to my lg shine from my computer.. HELP!!!!!!
The LG Shine is a nice phone, but it is very disappointing with the USB cable.
You may expect the cable would connect the phone to your PC for Calendar Sync, music, videos etc.
Obviously, this will not work.
It will only allow you to hook your LG Shine to your PC to copy music and video files ONLY if you have a Micro SD card in the phone inserted.
After you have copied the files to the Micro SD card from your PC, you can copy them to the phone memory.
There are nice websites with free management programs for also the LG phone, but the Shine is unfortunately NOT listed (yet).
Jan 01, 2009 | LG Shine KE970 Cellular Phone
How can I download music and videos on my i9 phone
To fix this problem go to your menu go to settings than go to connections, now go to the USB hit OK now you will see memory card access, data modem, application access, GPS NMEA and finally help. Make sure it is on memory card access and not any of the other ones the memory card access is to allow a PC to use your phone as a memory card reader. The data modem allows a PC to use your phone as a modem. Application access allows certain PC applications to access the phone. and finally the GPS NMEA allows the phone to output GPS signal from EMU port.
Nov 15, 2008 | Cell Phones
Cant put files or music in
when USB cord is attached to PC there is no sign of uploding or downloding forom PC, I am not able to do internet. In mobile when yahoo is connect without help of PC i.e dirctle in Mobile. it ask for e-mail ID and passward after giving the same, there is no axis to e-mail says pls do it once agin.. there is result.
my Model no is KE500
May 26, 2008 | LG KG800 Cellular Phone
Nokia 1100 Logo
118 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
