Question about Canon LASER SHOT LBP-5000 Printer
How can I reset canon lbp5000 with my greatfull for all
  • Cornerstone Fountain Church
    How do I reset Canon LBP5000 to factory setting
4 Suggested Answers
dumbtrucker
  • 102 Answers
SOURCE: Canon Laser Printer LBP5000 Need to Reset the printer
If it's a remanufactured cartridge take it back and exchange it for one that works.
Posted on Mar 24, 2009
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 217 Answers
SOURCE: lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Posted on Feb 10, 2010
Canon lbp5000
According to the user's guide all you should have to do is open the printer and remove the cartridge by the blue tabs. If it's stuck, then there is some component in the way and you'll have to get a tech to look at it. Here is a link to the User's Guide. http://gdlp01.c-wss.com/gds/1/0900006581/01/LBP5000_Manual_2_EN.pdf
The toner removal is on pages 5-4 - 5-16
Mar 17, 2014 | Office Equipment & Supplies
Canon LBP5050
Try update drivers for your Canon:
http://filedir.com/download/lbp5050/
Jun 14, 2012 | Canon LBP5000
My lbp5000 prints the colour image seperate from the black image, although it's supposed to be one image
The printer is need to Calibrate. Calibrate the printer from the menu in the taskbar down/right to the clock. Calibrate several times until printing is good.
Jan 08, 2011 | Canon LBP5000
Lbp5000 two sides print
Dec 09, 2009 | Canon LASER SHOT LBP-5000 Printer
My new computer can't talk to my Canon LBP5000
Your unit will work only on vista 32 bit system check canon for more details
Sep 11, 2009 | Canon LASER SHOT LBP-5000 Printer
Load Paper indicator problem - Canon LBP5000
You should have a cancel button on the printer press that and hit cancel job. if that does not fix it unplug the printer for a few min and it will clear. make sure when you send an envelope to one of these you select the right paper type and "manual feed" in your printer options so you do not cause this again.
Jun 22, 2009 | Office Equipment & Supplies
Mar 24, 2009 | Canon LaserBase MF3220 All-In-One Printer
Canon LASER SHOT LBP-5000 Printer Logo
1,137 people viewed this question
old marine
old marine
