Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Where can i fine manual for engine replacement
Where can i fine illustrated manual for engine replacement on a craftsmen dyt 4000 with 20hp kohler engine? I need instructions about pulley removal for crank end, thanks
  • 389 Answers
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Posted on Oct 05, 2009
    Problem Solver:
  • 6 Answers
The Kohler website has engine manuals. You have to have your serial number ready. I found and downloaded the manual for my 1998 20 hp Kohler Command there.
What's the wiring diagram for a craftsmen Kohler pro 17.5hp riding mower model number CV491S?
Not sure which charging system you have, so I have included both diagrams.
Feb 01, 2016 | Garden
The cluche wont ingage crafeman cv491s
  1. Free Kohler Service Manual Downloads : Kohler Engines ...
    https://www.kohler-engine-parts.opeengines.com/.../free-kohler-service-...Kohler Engines and Kohler Engine Parts Store Free Kohler Service Manual Downloads - Listed below are Kohler service repair manual in Adobe PDF format ...
Jul 15, 2015 | Cars & Trucks
Kohler exercise causes engine spikes and gasping for fuel.
On exercise it isn't under load, you may have too much gas pressure, have the gas pressure and fuel/air ratio checked on the mixer
Dec 16, 2012 | Kohler Generator 20kw 20res W/ 200 Amp...
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Dec 01, 2010 | Kohler 12 kW Emergency Power System -...
Need your assistance please
http://www.superxpower.com/pages/parts/viewbybrand/default.aspx
try this link, they don't deal specifically with craftsman parts, though they do have aftermarket suitable substitutes for craftsmen. This website has excellent illustrated parts breakdowns for numerous other riding lawnmowers though and I'll bet that something like MTD or White Outdoor is exactly the same as your mower. I have a White outdoor 42 inch riding mower and have changed numerous parts using these illustrations. Good luck
Apr 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsmen tractor needs engine.
http://www.smallenginewarehouse.com/
This will direct you to all kinds of engines. You pick the one that fits you tractor.
If it is a 26 HP Kohler engine you will spend about $1,500.00 for a new one.
You may want to consider 2 options.
Finding a used engine or replacing the tractor.
Please let me know what you find
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Will any other engine fit a craftsmen 26 hp lawn tractor other than the kohler
Yes there are 2 other options.
Briggs and Stratton, and Onan.
Here is the information. You will need to have your output shaft size.
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Aug 25, 2009 | Craftsman Garden
Electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
376 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
