Question about Olympus EVOLT E-500 Digital Camera
I was taking outside pictures, sunny day, sun at
I was taking outside pictures, sunny day, sun at my back, I think I changed a setting on my camera, because up to then my pics where awsome
5 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: When trying to take pictures outside the screen goes blank.
the screen is only adjusting to the brightness of the surroundings through the lens. This camera is working properly but many of the Olympus cameras just are bad with sunlight. Let me know if you have further questions
thanks
Posted on May 12, 2008
Agent Allan
  • 480 Answers
SOURCE: Digital camera woes
Hey libra2,
I would try resetting the camera to its default factory settings. Directions on how to do this are on page 20 of your camera manual, and I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 18, 2008
  • 4090 Answers
SOURCE: When taking pictures outside bright white photos
I suspect that the film speed is set incorrectly. You need to change the value of the ISO from the menu button near the LCD. Scroll through the menu till you come to ISO ( on film cameras this was the old ASA) for low light conditions one pushed the ASA to a higher rating like ASA 400 which was more sensitive to light, thus better pics in a low light environment.
So you need the opposite and so 100 ASA ( ISO) should help you take better pics in bright sunlight.. you can go as low as 64 if your camera has a setting that low.
Apertures will be different for each ISO value selected so when you look through the lens you will see numbers like F16 in the display ir F8 in a lower light situation.
Rule of thumb
Larger the number smaller the aperture ( sharper the image and for bright light situations
Lower the number larger the aperture to let in more light
average light F8 and this is usually the one the flash selects
Use your manual to learn how to manipulate the ISO and your manual selection of apertures. Your photos wilol improve 100%
Please rate our help to keep the service online
Posted on Aug 24, 2009
SOURCE: Why is my olympus e420 taking green tinted photos?
Im having this same problem. I have yet gotten it solved.. have you fixed it yet?
Posted on Feb 22, 2011
Vivitar 8225 screen goes blank on sunny day cant see picture i want to take
90% of point and shoot cameras have screens that are difficult or impossible to see in direct sun. You're not alone.
Dec 14, 2010 | Vivitar Cameras
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
Similar issue, no reason what the cause is
hi
i think the aparture and shutter settings an /or the exposure settings have changed try restting back to factory settings and things should get back to normal
happy clicking
pls rate if this was any help
Jul 13, 2009 | HP Photosmart R717 Digital Camera
Picture is white
Don't know your specific camera, but it sounds like you have it set on manual (does it have P, A, S, M settings?) with a long shutter speed. This would let in a lot of light outside, and make all of your pictures blurry.
Change your setting to P (program) or Auto (automatic) and see if that helps.
Mar 18, 2009 | BenQ DC E53 Digital Camera
Bright white exposure
This may be a ccd problem.
See this link.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Aug 06, 2008 | Canon PowerShot A80 Digital Camera
No picture when its sunny outside colour is distorted inside its a jvc digital cam gr-d33ag
On several camera the ccd is sensitive to bright and causes the images to come out very dark or out of focus because the auto focus sensor is being blinded. Try taking pictures with you back towards the sun and try turning off your flash this some times helps out. I hope this helps you and happy photo taking.
Mar 28, 2008 | Cameras
No pictures at all, at it's best just blury colours
got my developed film back and all I got were pictures seperated into 4 boxes with one colour a box. can you explain more can you look at the negatives and see whats on them. try a sunny sixteen rul on a sunny day with sun high in sky set camera aperture to F16 if you are using ISO100 film set the camera shutter to 1/100th ISO 200 = 1/200th etc take a picture of a stationary subject - like a brick wall whats the make and model of the camaera
Apr 13, 2007 | Lomo Action Sampler Kit Camera 35mm Point...
Olympus EVOLT E-500 Digital Camera Logo
56 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
