Question about Poulan Garden
My poulan leaf blower doesnt seem to have spark. So I pulled out the spark plug and dryed it out while i watched football, that counts as "fixin" time, doesnt it? I went to put it in this morning and dropped it. Just want to know the correct gap on the plug
  • 211 Answers
Hi
the sparkplug gap is 0.020 inch
bye
Posted on Oct 07, 2009
I have a poulan leaf blower that will not start.it sat for 2 years started once for about a minute
get a new plug and then check for spark. a spark checker is a better choice...and since I would be more inclined to believe you're not getting any fuel replace the carb and fuel lines. it's a waist of time trying anything else. just because you have fuel in the primer DOES NOT mean gas is getting to the engine. If you DO NOT have spark, but you have fuel, your spark plug WILL be fuel fouled (soaked with fuel)
Oct 16, 2014 | Poulan Garden
Spark plug
Champion is the kind of plug. most are 5/8 of an inch.
Jun 14, 2013 | Poulan Pro 25CC 2Cycle Gas Blower
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
Jan 07, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
Poulan leaf blower/vac won't run. It has spark, head bolts are tight, spark plug wet with fuel. (New plug) Any suggeastions?
that's the problem gas when wet won't burn
remove the sparkplug and, dry it off with rubbing alcohol then reinstall prime and, restart
Aug 31, 2009 | Garden
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Sep 22, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
150 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
