I can hear sound coming from the computer speakers however there is no sound whenver i have something to hear
  • 2 more comments
  • oscarmdlcjr Oct 05, 2009
    ok well I hear some static however i hear no sound coming out of the speakers....I have checked all the connections and they are connected correctly
    well I went to control panel and clicked on the sound icon and did test the sound and i heard it however whenever i wanna play music i dont hear anything from the speakers.....but i could hear the test sound that i ran in the sound tab
    I am trying to figure out why my lansing altec speakers are not working with my computer well I hear some static however i hear no sound coming out of the speakers....I have checked all the connections and they are connected correctly
    frwedf
  • 1,511 Answers
Hello and Welcome to FixYa!
Sir, kindly describe the query in detail, there is sound comming out of the speakers and then there is no sound whenever you want to hear something.
What type of sound is coming out of speakers, when idle?
I'm waiting for your response, in the form of detailed stance.
Regards, Waqar.
Posted on Oct 05, 2009
  • Waqar Hassan
    Waqar Hassan Oct 05, 2009
    Which Player are you using to here Music?
  • 742 Answers
Ok. Please check your device manager if you have all drivers for your sound card. 1. Right Click My Computer, Click Properties, Click Hardware Tab, then Click Device Manager. Make sure that all ITEMS under SOUND have no yellow ? in them which means that all drivers are installed and is working properly.
Now, make sure also that your speaker plug (jack) is plugged in the right port in your sound card. There are three ports, speakers usually plug into the green (middle) port depending on your card manufacturer. Anyhow, you can test it by playing a music and plugging the speaker to any of the ports.
Lastly, while your speakers are plugged into the right port, follow this to check sounds:
1. Click Start => RUN
2. Type "dxdiag" (without qoutes) and press ENTER
3. DirectX Diagnostic Tools window opens. Now, Navigate to the Sounds and Music Tabs and perform the tests there.
Hoppefully, you will hear the sounds and/or learn more about the cause of your sound problems.
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
Static coming from speakers
Not much information here but I will try my best, could be a problem with the cable your using between the speakers and the mp3 player, you could have a dry joint, if it's like a "hum" sound your getting it's a bad ground, without the mp3 playing plugged in tap the end of the stereo minijack cable with the speakers turned up? hear the 50hz buzz - if the interference sounds the same it's most likely a bad cable or bad connector on the speakers. I would need to either hear the interference to determine what fault it is or if you can describe it better i.e. what it sounds like.
Mar 31, 2014 | Altec Lansing Multimedia Computer Speakers
Can't hear the sound from the speakers
check your speaker or output of computer speaker input pin which plugin your computer just out and touch with hand hearing noise from your speaker if yes then see in computer sound mixure
May 20, 2012 | Audio Players & Recorders
My computer keeps saying there is something wrong with my sound card or audio device does that mean that it is something internal. I've tried the troubleshooting and even tried the control pannel settings.
if you cant hear anything coming out of your computer speakers there is something wrong here what to do
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP (400745-001) Sound Card
My speakers won't make a sound.
Process of elimination... check your cable hookup first. then control panel and check sound, right click on properties tab and do a diagnostic.
Jun 02, 2010 | Creative Labs Inspire T3000 Computer...
No sound coming from any of the speakers
PLEASE CHECK U ARE CONNECTING TO A PROPPER SOUND CARD IN A PROPER PLACE
PLEASE CHECK THE VOLUME LABLE IS HIGH OR MED .AND ALSO CHECK THE NOB IN BACK OF YOUR WOOFER THE BIG BLACK BOX IS APPRIOPRIATE VOLUME ATLIST MEDIUM AND SEEE IF U HAVE CONNET TO THE CORECT COLOUR CABLES IN CORRECT PLACE IT SHOULD WORK
Jan 04, 2009 | Logitech Z-640 Computer Speakers
No Volume to speakers
I rebooted my computer and reinstalled windows now my speakers dont work.How do I get them to work?
Jun 12, 2008 | Audio Players & Recorders
Deep Deep Sounds
Describe the control set up on the speakers and also the sound system on the computer
Jun 17, 2007 | Logitech R-20 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
