Question about Canon Speedlite 430EX TTL Flash
The flash won't fire, and the pilot light won't come on. I've tried new batteries, and that doesn't work. The little LCD screen does have power. I'm wondering if I blew the strobe. Thanks!
Hi ,
were you able to fix the flash ? what was the problem ? i am having exactly the same issue ..
kindly email me at shailesh.dabral@gmail.com
Posted on Jun 07, 2012
Hey i have a 430ex mk1 which when turned on did not fire and red pilot light did not show , i have had the flash since 2006,
i have also tired new batterys and the LCD Light works and the Txt shows up,
did you work out the problem and also how to fix it?
thanks
rick
email
psnp@hotmail.co.uk
Posted on May 07, 2010
Flash not firing, pilot light not on but display is fine
Hi John,
If your problem has not been fixed or a solution not found yet then you may consider this. Flash units are built with many tiny parts; thus, when a single component malfunction, it will render the whole unit useless. You mentioned the pilot light is not working - that indicates that power is not flowing through the unit.
Check the filament of the unit - if you notice some brownish stain on either end of the tube, it indicates the filament has burned out. Changing the type of batteries won't make any difference.
the only option you have now is to service the flash unit
May 10, 2016 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
DSI XL won't power on, but orange charge light is solid (doesn't blink) when charging.
dsi xl getting wrong voltage at plug that goes to the battery. I have 5.78 from charger at battery connections I have 5.78,3.87,0.45,1.98 it bounces all over any ideas?
Jan 25, 2013 | Nintendo DSi XL Console
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
I have a Toshiba Regza 47ZV650U 47" LCD TV that
I am having the exact same problem with my 47ZV650U, what was you solution
Jul 13, 2011 | Toshiba Televison & Video
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Open Questions:
See all Canon Speedlite 430EX TTL Flash Questions
Canon Speedlite 430EX TTL Flash Logo
791 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
