Question about Sanyo Katana SCP-6600 Cellular Phone
Sanya Katana will not power on and it has a fully charged battery
I have a Katana and it will not power up. I sent it in for repair and the report says water traces found around keyboard, screws and contact area. The battery does not show water damage and it has not been wet outside of using it with damp hands or wiping it down with a damp cloth for cleaning. We have swapped batteries with another Katana and still nothing and other phone works fine. Warranty place says water damage but has not proof such as a color dot or battery dot color change. Just says they did a swipe test and found traces of water as described above and rejected claim.
  • wishka70 Dec 22, 2007
  • 192 Answers
I must say that Wiska, cell phone are water accepting thing. It absorb water from climate like AC and fog. If it is realy damaged by falling in water then the service people can deny the claim. Otherwise there is no moral right to reject claim of valued customers. OK... It is their lookout. Let us discuss the problem. Now u can not do anything if they are not ready to accept their responsibility. But don't worry, there is another way. Any skilled technician can repair it after check wether it is short, open or leakage. This things are basic which are their routin testing of any circuit. There are lot of technician who posssess enough skills to workout this problem. Only ask fixya for such serviceman arround you.
Posted on Jan 07, 2008
2002 katana 750 battery not charging
Check the battery voltage with the engine running. It should exceed 13volts.
Aug 09, 2017 | 2002 Suzuki GSX 750 F (Katana)
Katana is not charging battery when it is connected in bike.
Hi, One thing you can do is put an off switch on the battery to stop the leak. What did you have done lately on the bike? ( new ignition switch or ??). Keep looking for all Grounds.
Jan 21, 2014 | 2002 Suzuki GSX 750 F (Katana)
Katana 600 manual
Did you charge it before you fitted it? It should be put on charge for 24 hours after the electrolyte has been added(acid). Then it should work. They don't come from the shop fully charged.
May 14, 2013 | 1999 Suzuki GSX 600 F (Katana)
When trying to start my 2001 katana it jus clicks doesnt turn jus clicks..i charged the battery already same..the wire to starter looks exposed and is a little loose were it connects to starter..
it must be tight on the starter.
check battery voltage when fully charged. it should read over 12.5v for a good battery. anything less then get a new one.
Mar 17, 2011 | 2001 Suzuki GSX 750 F (Katana)
My 1997 Suzuki 600 Katana came with a maintenance battery and i had it replaced with a maintenance free battery. The battery came fully charged and was ready to be installed. When I got home and installed,...
Hi and welcome to fixya,
Jump start the bike on 3rd gear to pre-charge the battery. its better to assume it was discharged and let the bike do the charging. Make sure all connections are in place and jumps start the bike, run a few kilometers. This should charge the battery pretty good for an electric start.
Hope this helps
Jan 31, 2011 | 1997 Suzuki GSX 600 F (Katana)
How do I replace the battery for a garmin nuvi 650
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Dec 12, 2009 | Garmin nuvi 650 GPS Receiver
Not charging
Your battery needs to be replaced. make sure you fully charge the new one and completly drain it before charging it again. don't interupt the charging till its full that will shorten the life of your battery consiterably!
Jun 09, 2009 | Sanyo Katana Eclipse X Cell Phone
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Garmin Nuvi 260W shuts off before it fully loads maps
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Cell Phone randomly powers off
most cell phones have lithium batteries that only have a certain life span. It may be worth your while to buy a new battery for the phone
Nov 21, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Sanyo Katana SCP-6600 Cellular Phone Logo
141 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
