Question about Aiwa PX-E860 Turntable
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
  • Aiwa Master
  • 3,289 Answers
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Posted on Oct 05, 2009
4 Suggested Answers
  • 1348 Answers
SOURCE: YAMAHA P-220 VINYL RECORDTURNTABLE SPEED PROBLEMS:- HOW CAN I
if you open the bottom,there is variable potentiometers for the speed adjustment.you need a strobe reference disc if you want it exact.
Posted on Aug 15, 2009
Grubhead
  • 5391 Answers
SOURCE: My LPDock turntable is surging
There are two possible causes, depending on if the deck is belt driven or direct driven. Sorry I don't know which with yours.
If it's a belt drive then the belt has come lose and should be replaced. Or the motor or power supply to the motor is faulty. Make a note of how the belt fits before you replace it.
With a direct drive it's either the motor or power supply to it that's got the fault.
Posted on Mar 06, 2011
  • 3 Answers
SOURCE: JVC Turntable model AL A1 BKX , need to know how to adjust speed
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
Posted on Dec 23, 2011
My JVC turntable has no plug, just a 10-13v lead
Probably as long it produces DC. However you will have to adjust the speed. As the unit was set for a certain voltage which wouldn't change. It will either go fast or slow depending on what the original voltage was. The speed adjuster will either be two presets one for each speed that could be located under the turntable base (covered by a sticker) or on the power board of the deck. Or they might be on the motor itself.
Apr 26, 2014 | JVC AL A158BK Turntable
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly?
Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it.
Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself.
You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
Apr 25, 2014 | Sony PS-LX250H Turntable
Slow turntable
I'm not certain if you know this already, but the light that shines on the left side causes a strobe effect on the platter. One of series of 4 patterns will seem not to move when the turntable is at the right speed. To adjust this you need a record playing and then move the slider on the right till the pattern doesn't move. Which one not moving will depend on the speed selected and also the mains supply either 50 or 60HZ.
You will get some variation in the movement, but you shouldn't notice the difference in the speed. If this is set up right and you still think it's slow, then you might have to look either right under the turntable or inside it. There might be on the underside one or two holes that might be covered up. They might even be labelled 45 and 33. If you find them you will need a small screwdriver and place it inside. This will turn a small speed pre-set. You will have to adjust this till you think it's right, with slight movements, testing with a record.
If they are not present on the underside you will have to take off the bottom and look inside for a pre-set. Normally it will look like a 3 leg device with a screwdriver slot in the middle of it. Sometimes marked on the board "VR" with a number. Alternatively it will be on the other end of the motor. If you have trouble locating it follow the motor leads to the main board.
Some turntables have two speed pre-sets others only one.
Dec 26, 2013 | Technics SL-1210M3D Turntable
Turntable out of Tune
it will be the turntable speed not exact
quality turntables have bars all around the circumference and when the speed is correct under a fluro light those bars will appear as stationary or using a strobe light set at 50 or 60 cycles a sec
bars going anticlockwise are too fast and moving forward are too slow
quality tables have a small knob or screw to adjust motor speed
Jul 27, 2017 | TDK Tvt2002 Usb Belt-drive Turntable
The turntable move too slow
There is normally a screw underneath the actual deck to adjust the speed.
May 21, 2012 | Philco (R) Classic Turntable CD Shelf...
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
My TEAC P688 is stuck in chipmunk mode for a large record - how do I slow it down?
Sometimes on the base of the turntable (under side) there are two presets one for the 45 speed and one for the 33. They might be hidden under a label or something. You might even have to go inside to find them. Anyway a small flat head screwdriver inserted in it should adjust the speed. You might have to work out which controls 33 speed. And of course if it is below you will have to figure out how to adjust it with a record playing. "Get out and get under!!!!" as they said about cars!
Jun 28, 2009 | Teac P-A688 Turntable
Slow turntable
Most older models had a rubber belt that will deteriorate over the years and if you cannot find one search in "O" rings at hardware store for correct size.
Feb 24, 2018 | Emerson MS9920TTR Shelf System
Aiwa PX-E860 Turntable Logo
749 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
