Question about Acer Aspire 1642ZWLMi Notebook
Acer laptop My acer laptop won't start up ive removed the battery and put it back and tried turning it on that way aswel..held the power button down for 60 seconds it stil hasn;t worked. all i get is a my two front lights flashing?
  • Humzy_00786 Dec 23, 2007
    That wasn't really helpful but thanks for the advice it may help with another problem my sister has with her pc but doesn;t really give me any insite on my laptops laptop just simply won't switch on??ive tried everything?apart from replacing both the battery and adapter.but i need some advice before i buy them because it could mean that i may be wasting money on new battery and adapter when there is a solution for the problem?
  • Anonymous Aug 19, 2008
    Mine also doesn't switch on. What actually happened is. I plugged my laptop in and it just switched off. I tried switching it on, to no avail. HELP
  • 383 Answers
How to create a boot disk. Insert a diskette that does not contain any information (it will be erased). ... of creating a MS-DOS startup disk, follow the below steps to do this.
How to remove TSRs As can be seen in the above picture the Applications window will only display .... Select the Startup tab and uncheck the programs you wish to not load up .
Good Luck, Read and follow instruction, Please dont for get to Vote/Thank You.
Getting into Windows Safe Mode Users who may not be able to boot into normal mode
Posted on Dec 23, 2007
My Acer Laptop not working
If it is not booting try this: Unplug the laptop from its power source and remove the battery. Then, hold down the power button for about 35 seconds. The computer isn't going to turn on, but what that will do is clear any static electricty off the board that commonly builds up on a laptop. After you've done that, put the battery back in and fire it up. If it doesn't start, let me know and we will work from there.
Jun 07, 2013 | Acer Aspire Computers & Internet
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
I have an acer aspire 5517-5086, it wont turn on at all, I removed and replaced the battery and tryed plugging it in also, with no results. is there a reset button or something?
worked for me. my acer aspire will go to sleep and never turn back on sometimes. the light on the power block will fade out and nothing will turn on. I pulled the battery out, left it for 10 minutes ..plugged in the power jack, wrapped the f10 key then held it down and presto! power!
happier acer user.
Oct 18, 2010 | Acer Computers & Internet
Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Mar 05, 2010 | Acer Extensa 5630-6806 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Acer aspire laptop suddenly shut off and cannot turn back on
try it without the battery on the laptop. if it boots and stays on, put the battery back on and see what happens. If the problem persists, replace the battery. Acer will replace it free if you are still in warranty
Aug 09, 2009 | Acer Aspire 2930-4661 Notebook
Acer laptop wont turn on has power button light up
This is a common problem with Acer units, both desktop and laptop. The motherboard fails to read the system BIOS at startup. Removing the battery from a laptop merely removes the power source, but not the stored memory. If you are able to locate the CMOS battery, or the cell battery the size of a US quarter dollar, that is the system battery. Remove that, wipe with a lint free cloth (coffee filter) then replace.
If that effort fails upon replacing the cleaned CMOS battery and laptop eneregy source, then a new coin cell may be the solution.
If a new coin cell fails to resolve the problem, the motherboard itself is the culprit. Time for a new laptop or desktop.
Hope this helps you...
Dec 29, 2008 | Computers & Internet
Acer laptop
First thing to try would be to remove the battery and unplug from the mains, then hold down the power button to discharge all electricity from device, You will need to hold down power button for 1-1.5 minutes.
Once this is done put the battery back in and try again. Let me know how you go.
Jun 03, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 1642ZWLMi Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
