Question about Cell Phones
How do i disable voice dialing on my verizon samsung intensity
Unfortunately these cell phone companies aren't smart enough yet to understand that 98% of the time these 'disability features' on phones are only used by accident by people not wanting to use them.
There is a way to make it less annoying though. Go open up that stupid voice command, go to "settings>prompts>mode>tones only" - this will make it not talk to you.
And the next one will take it off of speaker phone, and into the earpiece:
"settings>prompts>audio playback>earpiece"
I encourage you to complain as much as possible to verizon and samsung so they'll fix these annoying flaws that they make in every phone.
Posted on Jun 08, 2010
How can I get my samsung intensity 2's back light to turn off?
I suggest that you take it to the nearest Verizon store and ask them for technical assistance. It sounds as if there might be a mechanical problem with the phone.
Oct 28, 2015 | Samsung Intensity II U460 Verizon
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
Hod do i turn call forwarding off
Select Setting on your phone
Then go to call settings
Scroll down to Call Forwarding and click
Select Voice call
Then select where you want to disable
And click Disable
Mar 04, 2015 | Samsung Convoy 3 Mobile Phone - Gray...
Where is the sim card slot .of samsung u460 verizon
Verizon's version of the SCH-U460 doesn't have a SIM. It's CDMA.
In the U.S., CDMA carriers use network-based white lists to verify their subscribers whereas GSM carriers like AT&T put customer information on a removable SIM card.
USER MANUAL
Samsung Intensity II QWERTY Cell Phone
Jan 28, 2014 | Samsung Intensity II U460 Verizon
Remove sim card
Sorry, no SIM card in this phone as it's a CDMA phone for Verizon's CDMA network.
MANUAL FOR U460
Voice command
Go to Settings & Tools, Choose Tools.Shut off voice commands.
May 30, 2012 | Samsung Intensity II U460 Verizon
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
I would like to know how to enable voice-dialing on my Samsung Intensity, I cant seem to figure it out....thanks
Voice dialing is enabled by default on the Intensity. All you have to do to use it (assuming you have at least one contact saved) is press the voice dialing button on the upper right side of the phone (near the camera) and on the menu that pops up, select Call (option #1). Then say the contact name you want to call -- for example, "Call Michael." You may have to confirm your selection, depending on your settings, and then the phone will dial the number you have saved for Michael.
Apr 17, 2010 | Samsung SCH-U450 Cell Phone
Cell Phones Logo
2,297 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
