Question about LG WM-2277HW Front Load Washer
Oe code please help me oe drain error code
  • 2 more comments
  • fiona-joseph Aug 10, 2008
    I cleaned the front drain. I still have the same error code oe
  • epblj Aug 11, 2008
    Same problem here! Took off the drain hoses and rinsed them out, they were clear. We clean out the 'trap' once a month so it's not that. The washer makes a grinding type noise when trying to drain, also like something is caught in the pump or something. How do you access the pump?
  • Anonymous Sep 26, 2008
    I ran into the same problem. I took the washing machine outside and opened the front trap and ran about 10 gallons of water through the system. Then I back washed the system by running water through the drain hose at a high pressure for 2 or 3 minutes. I had some very ugly grime/sludge come out of the drain hose. I flushed the system until it was clear. Then I put some drain-O into the drain hose and let it set for a few minutes and flushed it again. I put it all back together and brought it back into the house and the system worked perfectly.
    I was very worried it was the pump, but turned out not to be the case...
    Good Luck...
  • reneblanca1 Nov 20, 2008
    the washer makes a grinding type noise when trying to drain, also like something is caught in the pump or something.
I have the same problem with the Daewoo front loader i've drained it and done everything in the instruction manual done all the drain filter and nothing is working
Posted on Mar 08, 2012
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Posted on Aug 15, 2008
OE is drain problems pull the front cover and access the pump and clean it out/check drain line for blockage or kinks
Posted on Dec 27, 2007
rickzilla
  • 706 Answers
SOURCE: LG tromm front loader OE
This may be obvious but have you cleaned the filter that precedes the pump? Open the small access panel on the bottom left ( front of the washer) and twist out the filter trap.. clean all debris.. and the little bit of water that trickles out onto your floor.. Hope that helps...
Posted on Aug 29, 2008
  • 1294 Answers
SOURCE: lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Nov 28, 2007
blueextc3221
  • 15935 Answers
SOURCE: LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Posted on Sep 15, 2010
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
wm- 12225fd
Posted on Dec 11, 2007
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
My washing machine is giving me code OE. it is not not spinning. checked the belt and it is fine. any help would be great. thanks kylie
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Washing Machines
Won't drain code OE
Hi co3256,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 19, 2011 | LG Dishwashers
Getting an error code OE in LG inverter direct drive dishwasher and water not draining
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
Kind Regards :-)
Jun 09, 2011 | Dishwashers
Fault code oe please explain what this means
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html if you have any further questions message me back and please remember to rank how this opinion has helped in your applaince situation it allows me to help others in similar situations Thanks
Rick
Mar 24, 2011 | LG Washing Machines
OE error
Jul 09, 2010 | LG WM2233H Front Load Stacked Washer /...
Jan 12, 2010 | LG WM-2277HW Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,702 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
